  3. How to determine if an instance is a frozen p-cell?
  • Views 12419
Byron Caloz
Byron Caloz over 4 years ago
I would am looking into a skill script to freeze parameterized cells (p-cells) and another to unfreeze them.
Freezing should be relatively easy...just find a instance of a p-cell, determine a name for it, then run leFreezeInst.  (determining a unique name may be difficult, but it needs to be the same name applied with each freeze-unfreeze cycle if no parameters were changed).
However, unfreezing without warning messages requires a way to determine if an instance is a frozen pcell.
One could run leUnfreezeInst on any non-pcell and disregard WARNING LE-105622 Unable to find enough information to unfreeze this instance.
Clearly leUnfreezeInst knows what information is required to unfreeze.
Attempted to determine what leUnfreezeInst is using:  inst->??  but I didn't see anything useful.  Am I missing something?
Did see a script from Cadence to unfreeze instances, but it doesn't look as if it checks for anything: just runs leUnfreezeInst.
Looking for skill to find the information that is used to unfreeze an instance!
  • AurelBuche
    AurelBuche over 4 years ago +1
    Hi, Not sure if this will help you but the following Support article has a code snippet using freeze / unfreeze functions SKILL script to freeze pcell instance to stop pcell evaluation and unfreeze…
    Andrew Beckett over 4 years ago in reply to AurelBuche +1
    The information is stored in a hidden (private) property which I don't want to state here as it might well change in future (that's why it's hidden). It would make sense to contact customer support to…
  • AurelBuche
    SKILL script to freeze pcell instance to stop pcell evaluation and unfreeze it later
    Even though this is not the best way to do it, you could ignore the warnings with a brutal call to muffleWarnings
    (Which is available since 6.1.8 if I remember correctly, otherwise you could write a similar macro which redirects woport to /dev/null and catches buffered warnings using getWarn)
    Cheers
    Aurélien
    It would make sense to contact customer support to ask for a function, something like: leIsInstFrozen(instId) as an enhancement.
    So for now, the approach suggested by Aurélien is likely to be the cleanest:
    muffleWarnings(leUnfreezeInst(instId))
    which will return t if successful, and nil if it wasn't "thawed".
  • Byron Caloz
    Byron Caloz over 4 years ago in reply to Andrew Beckett
    Thank you!  I was unaware of muffleWarnings.  That may come in handy for other situations as well.
  • Byron Caloz
    Byron Caloz over 4 years ago in reply to AurelBuche
    I will use muffleWarnings initially, but I like the idea of writing my own specific one so I can distinguish between different types of failures, if any.  Thanks!
