  3. Apply 'and/'or to a list of lists
  • Subscribers 150
  • Views 2056
FormerMember
FormerMember over 4 years ago
I have a function, which generates a list of results. The results are lists, which can also be nil in case of an error.
I want to check if, all results are valid with 'and' or if some are invalid with 'or'. However, when I use the 'apply' function, I get an error because the lists are tried to be evaluated. Here is an example with 'and' but the same happens with 'or'
and( '(1) '(2) '(3)) -> '(3)
and( '(1) '(2) nil) -> nil
apply('and '((1) (2) (3))) -> *Error* eval: not a function - 1
I can achieve the same result with a 'forall' loop but it requires more code and is probably slower? Also, it requires an ugly inversion, to emulate the 'or' behavior.
Is there a way to prevent the evaluation of the arguments in an 'apply' call with 'and' or 'or'? Also, is there a way to know, which functions cause this? So far, I only observed this with and/or.
Best regards
Paul
  • AurelBuche
    AurelBuche over 4 years ago in reply to Andrew Beckett +1
    Andrew gave you the equivalent for (apply 'and ...) with forall The equivalent for (apply 'or ...) is exists (exists x yourList x) Cheers Aurélien
    Paul,
    That's because and is a syntax form - usually it selectively evaluates its arguments - this allows "expression short-circuiting" which means that the later arguments are only evaluated if the earlier arguments are true. So that allows things like:
    boundp('someVar) && someVar
    to work - if the variable is not bound, it will never get to the second expression.
    As an alternative, you could use:
    forall(x yourList x)
    which will return t if all values in yourList were non-nil.
  • AurelBuche
    Cheers
    Aurélien
