  3. How to ungroup figGroup inside a figGroup with skill co...
  • Views 12054
How to ungroup figGroup inside a figGroup with skill code
wenckey
wenckey over 4 years ago
For example, groupB inside groupA , I want to use a command to ungroup both groupA and groupB (like flatten to bottom)
I only found the command leHiUngroup() which used to ungroup the selected group
    The simplest is to just use dbDeleteObject to delete the fig groups. The objects within the figGroup don't get deleted - they remain part of the cellView. There is also dbRemoveFigFromFigGroup, but you…
    The simplest is to just use dbDeleteObject to delete the fig groups. The objects within the figGroup don't get deleted - they remain part of the cellView. There is also dbRemoveFigFromFigGroup, but you'd have to process each figure one at a time that way, and the figGroup would remain at the end.
