  3. SKILL - lemarknet() highlighting only particular layers
  • Views 5317
JRP29
JRP29 over 4 years ago
I want to highlight or mark a net in a layout with only particular metal using SKILL. I tried using leMarkNet() with inputs - XY and start layer. But there is no provision to give the stop layer.
Is there any way to highlight a net with only particular layer using SKILL?
    Andrew Beckett over 4 years ago in reply to JRP29 +1
    You could create an options file something like this: # Do not remove or change these header lines. # markNetOptions file version 1.0 viaLayers( Metal3 y0 Metal4 t ) I am wanting to do a mark net with…
  • AurelBuche
    AurelBuche over 4 years ago
    Hi
    I made you a code snippet from different scripts I had
    Hope this does the job you want
    Don't hesitate if you have any question
    Cheers
    Aurélien
    ;; SKILL++ is necessary for several reasons
    ;; - Parameters can be dependent as they are
    ;; defined in sequential orders (same as letseq)
    ;; - It allows to define local functions but
    ;; provide only the specified ones in global name space
    (inScheme
      ;; Closure so functions are defined locally by default
      ;; Variables defined here are shared between those functions
      ;; but do not pollute global name space
      (let (hl_set)
        (defun reset_hl_set (win)
          "Delete previous highlight set and make sure current one is valid"
          ;; Delete hl_set when it exists already
          (when hl_set (geDeleteHilightSet hl_set))
          ;; Create an highlight set and enable it
          (setq hl_set (geCreateWindowHilightSet win '("hilite" "drawing1")))
          (setf hl_set->enable t)
          (geSetHilightSetHaloParameters hl_set "over" "fadeout" "thin" 20)
        ;; The following function is global thanks to defglobalfun
        (defglobalfun custom_highlight_net_shapes (@key (win (hiGetCurrentWindow))
                                                        (cv  (geGetWindowCellView win))
                                                        ;; Here you can provide either ?net_names as a list of strings
                                                        ;; or ?nets as net dbobjects
                                                        net_names
                                                        (nets (foreach mapcar name net_names (dbFindNetByName cv name)))
                                                        layer_names
                                                   ;; Safety measure and support for future developments
                                                   ;; This avoid issues in case the function arguments change
                                                   @rest _args)
          "Highlight NETS shapes in LAYERS"
          ;; Reset highlight set
          (reset_hl_set win)
          ;; Browse nets
          (foreach net nets
            (when (and net (dbIsId net) (equal "net" net->objType))
              ;; Highlight net figs of the specified layers
              (foreach fig net->figs
                (when (member fig->layerName layer_names)
                  ;; Highlight fig
                  (geAddHilightFig hl_set fig)
              ;; Fetch net instance pin shapes as well
              (foreach conn net->memInstTerms
                (setq conn (car conn))
                (let ((inst conn->inst))
                  (foreach pin conn->term->pins
                    (foreach fig pin->figs
                        ;; Best I found here is to highlight instance shapes rectangles
                        ;; Instance figs are not highlighted using geAddHilightFig
                        ;; I believe it would be highlighting the master fig and
                        ;; not the instanciated one
                        (geAddHilightRectangle hl_set (dbTransformBBox fig->bBox inst->transform))
              ));foreach net
          );def
        );closure
      );SKILL++
  • JRP29
    JRP29 over 4 years ago in reply to AurelBuche
    Hi  Aurélien,
    Thanks for the Reply.  Based on my understanding of the script you provided, we need net info to highlight the net.
    But I only have the XY coordinate information and the desired metal layer information to highlight a net.
    viaLayers(
    Metal3 y0 Metal4 t
    I am wanting to do a mark net with Metal3 - so I created a dummy via using y0 as the via layer (so that doesn't exist), and hence it will only mark Metal3 (if I start from Metal3). Then you can pass ?optionFile to the leMarkNet function.
  • JRP29
    JRP29 over 4 years ago in reply to Andrew Beckett
    Thanks Andrew.
    The above method solved my issue.
  • RicardoGV1
    RicardoGV1 over 4 years ago in reply to AurelBuche
    Hi  Aurélien,
    How Am I supposed to use that script? I call the function custom_highlight_net_shapes with different arguments and none works. also called the whole script and don't work.
    I'm already using .ils file. Also tried with toplevel('ils)
    In case this is the problem, I added a ")" at the end, cause there was missing one and didn't allow me to load the script without it
    getVersion()->virtuoso version 6.1.8-64b
    getVersion("virtuoso")->sub-version IC6.1.8-64b.500.22
