  3. How to use the pcDefineRepeat, pcDefineInheritParam functions...
  • Subscribers 150
  • Views 11732
How to use the pcDefineRepeat, pcDefineInheritParam functions?
yankunRen
yankunRen over 4 years ago
Hi,Everyone
I am using the IC616 version.
I want to create a hierarchical pcell.  In pcell1, pcell1 can inherit the w,l parameters of pcell0,
and pcel0 can be repeated in the X direction, Y direction.
I know about using the pcDefineRepeat and pcDefineInheritParam functions, but I don't quite understand how they are used.
I wrote the Skill code, but it can't realize the function, I don't know how to modify it, please help me, thank you very much!!!
Code:
/*** pcell0 ***/
pcDefinePCell(
list( ddGetObj("test_pcell") "pcell0" "layout")
(w float 2.0)
(l float 2.0)
let( (cv thinRect)
cv=pcCellView
thinRect = rodCreateRect(
?layer list("thin" "drawing")
?width w
?length l
?origin (0 : 0)
?subRectArray
list(
list(
?layer list("mt1" "drawing")
?width w
?length l
?lowerLeftOffsetX 0
?lowerLeftOffsetY 0
?upperRightOffsetX 0
?upperRightOffsetY 0
);end list
list(
?layer list("cont" "drawing")
?width 0.45
?length 0.45
?spaceX 0.45
?spaceY 0.45
?lowerLeftOffsetX 0.18
?lowerLeftOffsetY 0.18
?upperRightOffsetX -0.18
?upperRightOffsetY -0.18
);end list
);end list
);end thinRect
) ;let
) ;pcDefineCell
/*** pcell1 ***/
pcDefinePCell(
list(ddGetObj("test_pcell") "pcell1" "layout")
(w float 2.0)
(l float 2.0)
(x int 1)
(y int 1)
let((cv pcell0ID)
cv=pcCellView
pcell0ID = dbOpenCellViewByType("TestSkill" "pcell0" "layout" "maskLayout" "r")
pcDefineRepeat(
cv
pcell0ID
list('x 'y)
'6
'6
'x
'y
nil
nil
'((fix(pcRepeatX) - 1) * pcStepX)
'((fix(pcRepeatY) - 1) * pcStepY)
"horizontal and vertical")
);end let
);end pcDefinePCell
Best regards,
yankun
    Hi Yankun,
    You shouldn't use these in SKILL code; they are used by the (old) graphical PCell Editor in Virtuoso. At the start of the chapter where pcDefineRepeat is defined, it says:
    Graphical Parameterized Cell Functions
    This chapter describes each of the supported pc functions you can use to create Pcells in the graphical Pcell environment. Do not use the functions in this section within the body of SKILL Pcell code.
  • yankunRen
    yankunRen over 4 years ago in reply to Andrew Beckett
    Thank you for your reply,Please what functions should I use to achieve my functionality。I'm a little confused now。
    If you can, please give me a Skill reference, thank you very much.
    Please forgive my bad English.
    yankun
    Something like this should give you the idea as to how to do this:
    /*** pcell0 ***/
    pcDefinePCell(
        (w float 2.0)
        (l float 2.0)
      let( (cv thinRect)
        cv=pcCellView
    ;      ?layer list("Oxide" "drawing")
          ?width w
          ?length l
          ?origin (0 : 0)
          ?subRectArray
            list(
              list(
    ;            ?layer list("Metal1" "drawing")
                ?width w
                ?length l
                ?lowerLeftOffsetX 0
                ?lowerLeftOffsetY 0
              );end list
              list(
    ;            ?layer list("Cont" "drawing")
                ?width 0.45
                ?length 0.45
                ?spaceX 0.45
                ?spaceY 0.45
              );end list
            );end list
        );end thinRect
      ) ;let
    ) ;pcDefineCell
    /*** pcell1 ***/
    pcDefinePCell(
        (w float 2.0)
        (l float 2.0)
        (x int 1)
        (y int 1)
      let((cv)
        cv=pcCellView
        dbCreateParamSimpleMosaicByMasterName(
          cv
          "test_pcell"
          "pcell0"
          "layout"
          "M0"
          0:0
          "R0"
          x
          y
          ; add some spacing (not sure what you really want)
          w+0.5
          l+0.5
          list(
            list("w" 'float w)
            list("l" 'float l)
