  3. how to perform callback from browse button
  • Replies 9
  • Views 14852
saurabh96
saurabh96 over 4 years ago
Hi there,
i have made a string box and browse button
path_enter=hiCreateStringField(
?name 'path_enter
?defValue "/xyz/cadence/2022.12.22"
browse_Entry=hiCreateButton(
?name 'browse_Entry
?buttonText "Browse..."
?callback "ddsFileBrowseCB(hiGetCurrentForm() 'path_enter \"\" 'directoryOnly)"
?callback "PathCB(hiGetCurrentForm())")
procedure(PathCB(form)
case(form->Entry->value
("Test"
unless(boundp('MyInCallback) && MyInCallback
let((pat (MyInCallback t))
pat=pcreCompile("/[^/]*/[^/]*/[^/]*/[^/]*")
form->path_enter->value=strcat("/xyz/cadence" pcreReplace(pat form->path_enter->value "" 1))
I want that above procedure (PathCB(form) only works when i press the browse button
so how can we use two callbacks one for directory surfing and other for procedure calling using browse button.
Please guide.
Thanks in advance.
  • skillUser
    skillUser over 4 years ago in reply to saurabh96 +1
    Hi Saurabh, Put the hiDisplayFileDialog callback in double quotes, then it will get activated when the button is pressed, rather than when the code is loaded/read. Best regards, Lawrence.
    You asked the same question a couple of months ago, and I gave a suggestion there (to use hiDisplayFileDialog).
  • saurabh96
    saurabh96 over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    Yes i remembered...but i didn't get it.
    Can you please help me with example or test-case
    Andrew Beckett over 4 years ago in reply to saurabh96
    Over many months you've had countless examples provided on how to write callback functions and create form and form fields. I would have expected it ought to be clear enough by now (and I've also suggested attending the free online training too). I'm not going to write a full example, but it would be this:
    create a "browse" button - button callback will call hiDisplayFileDialog() with appropriate arguments and a callback
    create string field that you can type in characters; this doesn't need a callback
    The callback for the hiDisplayFileDialog will do whatever processing you want on the selected file and then fill in the string field. This way the path processing only happens when you've used the browse button.
  • saurabh96
    thanks for help!
  • saurabh96
    saurabh96 over 4 years ago in reply to saurabh96
    Hi Andrew/everyone.
    I tried a test-case below...its working correct but the file browser is coming as soon as load the file without pressing browse button...can you please guide what the glitch?
    path_enter = hiCreateStringField(
    ?name 'path_enter
    ?defValue "/xyz/cadence/2021.12.22"
    Entry = hiCreateFormButton(
    ?name 'Entry
    ?callback hiDisplayFileDialog(
    ?dialogName 'myFileDialog
    ?callback "MyTrimPathCB"
    procedure(MyTrimPathCB(form)
    hiCreateAppForm(
    ;; the form variable is global, this is required
    ?name 'myTestForm
    ?formTitle "Browser test form"
    ?fields list(
    list(path_enter 0:0 420:30 50)
    list(Entry 430:0 70:30)
    hiDisplayForm(myTestForm)
    ); let
  • skillUser
    Hi Saurabh,
    Best regards,
    Lawrence.
  • saurabh96
    saurabh96 over 4 years ago in reply to skillUser
    Thank you Lawrence!
  • saurabh96
    Hello Lawrence,
    am getting error as Error* MyTrimPathCB: too many arguments
    for the below script-
    ?name 'path_enter
    ?name 'Entry
    ?callback strcat("hiDisplayFileDialog(?dialogName 'Select"
    " ?mode 'directoryOnly"
    " ?callback \"MyTrimPathCB\")")
    Seriously? You can't diagnose that after all these posts about callbacks? Please read the documentation on hiDisplayFileDialog - it shows that the callback function needs to be defined to take 2 arguments (or 3 if ?userData is passed to hiDisplayFileDialog). Your callback only has one argument which is the form (the arguments need to be the dialog itself and the event).
    Because I can't bear this going back and forth longer, here's a small example - showing a clean way of passing the form to the dialog box callback so that your code can update the main form. Call MyDisplayForm() to launch the example form.
    procedure(MyCreateForm()
      hiCreateLayoutForm(
        'MyDummyForm
        "Example Form for Forum"
        hiCreateFormLayout(
          'MyLayout
          ?items
            list(
                ?name 'filePath
                ?prompt "Path"
              hiCreateButton(
                ?name 'browse
                ?buttonText "Browse"
                ?callback "MyLaunchFileDialog(hiGetCurrentForm())"
    procedure(MyDisplayForm()
      hiDisplayForm(MyCreateForm())
    procedure(MyFileDialogCB(dialog event formName)
      ; the user data has to be passed as a symbol, so
      ; use symeval to get the form itself
      let(((form symeval(formName)))
        printf("EVENT IS %L\n" event)
        when(event=='done
          form->filePath->value=car(hiFileDialogSelection(dialog))
          ; here is where you'd call your TrimCB function
    procedure(MyLaunchFileDialog(form)
        ?dialogName 'MyFileSelect
        ?callback "MyFileDialogCB"
        ?userData form->hiFormSym
