  3. How to get the filename from the filepath
  • Views 13551
saurabh96
saurabh96 over 4 years ago
How can we get the filename from the filepath?
for eg ---
I have file path -              /xyz/pwd/lie/cadence/test/file1
I want file1 as output from above filepath?
    Andrew Beckett over 4 years ago in reply to AurelBuche +2
    AurelBuche said: Not sure this is the right place to mention that but if you go with Andrew's second solution, please be careful with pcreSubstitute as it relies on rexMagic switch That's not good. I…
  • AurelBuche
    AurelBuche over 4 years ago +1
    There you go: (defun cst_basename (path "t") "Equivalent to Unix basename" (let ((base (rindex path "/"))) (if base (substring base 2) path))) Cheers Aurélien
    Andrew Beckett over 4 years ago in reply to saurabh96 +1
    That is using SKILL commands. You just want yet another way? Not sure why you can't just use Aurélien's suggestion... baseName=car(last(parseString(path "/"))) or: basePat=pcreCompile("[^/]*$") baseName…
  • AurelBuche
    There you go:
    Cheers
    Aurélien
  • saurabh96
    saurabh96 over 4 years ago in reply to AurelBuche
    Thanks Aurel...
    Apart from this is there another way using skill commands (parse string , cdr)?
    or:
    baseName=pcreExecute(basePat path) && pcreSubstitute(basePat "\\0")
    There are of course many ways of doing this.
  • AurelBuche
    AurelBuche over 4 years ago in reply to Andrew Beckett
    That's not good. I hadn't realised that and it's poorly documented. I think that's rather dangerous (I dislike global switches with a passion). I'll take that up with R&D...
    • Vote Up +2 Vote Down
