  3. Copy a defined set of designed variables into multiple ...
  • Views 11691
Copy a defined set of designed variables into multiple tests
greywanderer
greywanderer over 4 years ago
I would like to copy a defined set of variables in a test to other similar tests in Assembler, so that I know they are exactly the same. Is there a way to do this?
Thanks much!
    You can use Session->Import in Explorer to do this (for a specific test), or you can use Right Mouse over the Design Variables to export/import a CSV file.
    In Assembler, you can also use File->Import to import the global variables, and can export/import a CSV file by RMB over the Global Variables.
    Finally, you could use the Setup Library Assistant (I'm sure there's a RAK on this) to define sets of variables (and sweeps and corners) to reference; this uses an ADE Verifier license, but is pretty convenient for ensuring consistency.
