  3. Stop DRC check on device import from happening
  • Views 10198
StephanieIFX
StephanieIFX over 4 years ago
When I import devices into a layout with Gen from Source or Update Components and Nets, I get a bunch of warnings similar to the ones below.  How do I turn this check off?  This check takes up so much time on import and it is not helpful.
*WARNING* ***Left dummy poly is removed : this will cause DRC violation***.
*WARNING* ***Right dummy poly is removed : this will cause DRC violation***.
Stephanie
    Hi Stephanie,
    I believe that is coming from the PDK; as far as I can see, it's not a message our tools produce.
    You might want to take this up with the foundry/PDK provider.
