  3. search for pattern in a string
  • Subscribers 152
  • Views 14813
greywanderer
greywanderer over 4 years ago
How do you search for a pattern in a string and return the pattern found?
For eg. say the string "/a/b/c/Interactive.123/d/e/"
And regex pattern is "Interactive.[0-9]+".
Is there a skill function that returns "Interactive.123" when function("/a/b/c/Interactive.123/d/e/" "Interactive.[0-9]+")?
Thanks!
  • skillUser
    skillUser over 4 years ago +1
    Hi, str = "/a/b/c/Interactive.123/d/e/" => "/a/b/c/Interactive.123/d/e/" pat = pcreCompile("(Interactive\\.[0-9]+)") => pcreobj@0x2aa37260 pcreExecute(pat str) => t pcreSubstitute(pat "\\1") => "Interactive…
  • henker
    henker over 4 years ago in reply to skillUser +1
    You can get the actual match also with \\0. This does not require an explicit capture group around the whole pattern, e.g. pcreCompile("Interactive\\.[0-9]+") without the capture parentesis in the regex…
    Andrew Beckett over 4 years ago in reply to henker +1
    In addition to \\0 you can also use & - so: pcreSubstitute(pat "&") will do the same thing. Of course, your pattern could also be "Interactive\\.\\d+" (\d is perl regular expression for a digit). …
  • skillUser
    => t
    => "Interactive.123"
    The "." in the pattern needed to be escaped otherwise it means 'any single character' rather than a literal dot. The whole captured pattern is surrounded with parentheses, and since this is the first captured pattern it is referred to as \\1 in the replacement, this is what the pcreSubstitute function is returning to us, the first captured (sub)-pattern.
    Best regards,
    Lawrence.
  • henker
    You can get the actual match also with \\0. This does not require an explicit capture group around the whole pattern, e.g. pcreCompile("Interactive\\.[0-9]+") without the capture parentesis in the regex and pcreSubstitute(pat "\\0") will do the same and may be a bit more intuitive.
