  3. How to store values for the form fields
  • Subscribers 150
  • Views 12536
yankunRen
yankunRen over 4 years ago
Hi All
    I have the following problem while writing SKILL. (IC616)
    Q1: How do i store the last used field value here in the following function?  I would like use the last used Library again when i go back to the form field so that i dont have to type in every time.
    Q2: How to change the size of Options form, it's too long. And remove the "Last" "Defaults" button.
    Q3: How to use ?doneProc in enterBox(), I want to keep using enterBox() function until I press ESC.
press  F3  Form:
Here is part of the code
Code:
procedure(test()
let(()
cv=geGetEditCellView()
optionsForm = hiCreateOptionsForm(
'optionsForm
"Options"
list(
Type = hiCreateRadioField(
?name 'Type
?prompt "Type"
?choices list("type1" "type2")
);end Type
);end list
nil
);end optionsForm
box = enterBox(
?form eval(optionsForm)
;?doneProc
printf("%L\n" box)
if(optionsForm->Type->value == "type1" then printf("%L\n" car(box)))
if(optionsForm->Type->value == "type2" then printf("%L\n" cadr(box)))
);end let
);end procedure
hiSetBindKey("Layout" "<Key>z" "test()")
Thank you all!
yankun
    Hi Yankun, I updated the code (with comments) to show how to achieve the three questions you had. See below. The key changes are: Check to see if the form already exists - that means it will remember…
    Hi Yankun,
    1. Check to see if the form already exists - that means it will remember current settings on the form rather than creating fresh each time
    2. Change to use hiCreateAppForm as this has more options - such as the ability to set the buttonLayout and the initialSize
    3. Move the action into the doneProc and give an example of that. It seems that enterBox does not honour the "repeat commands" in the layout editor, so I have emulated it in the doneProc.
    procedure(testDoneProc(wid done box)
      ; don't do anything if cancelled
      when(done
        printf("%L\n" box)
        ; enterBox doesn't seem to honour modalCommands itself ("Repeat Commands"
        ; on the Editor Options form) so achieve the same thing
        ; by enqueuing the original command again
        when(envGetVal("layout" "modalCommands")
          hiEnqueueCmd("test()")
    procedure(test()
      let((optionsForm box)
        ; Only create the form if it doesn't exist already; always
        ; stored in a global variable, so make sure the name is unique
        unless(boundp('CCFuniqueOptionsForm)
          ; hiCreateAppForm has more control than hiCreateOptionsForm
          hiCreateAppForm(
            ?name 'CCFuniqueOptionsForm
            ?formTitle "Options"
            ?formType 'options
            ?fields list(
              hiCreateRadioField(
                ?name 'Type
                ?prompt "Type"
              );end Type
            );end list
            ; Control buttons and initial form size
            ?buttonLayout 'HideCancelDef
            ?initialSize 300:60
          );end optionsForm
        optionsForm=CCFuniqueOptionsForm
        ; Moved the processing into the doneProc
        box = enterBox(
          ?doneProc "testDoneProc"
      );end let
    );end procedure
  • yankunRen
    yankunRen over 4 years ago in reply to Andrew Beckett
    Thank you Andrew,
    That is exactly what i need.
    Thank you very much.
    Best regards,
    Yankun
