  3. Reduce Marknet speed in identifying Short
  • Views 9774
John Z
John Z over 4 years ago
Can i know is there any possible ways to reduce the marknet speed. It will be very helpful during debugging short as we can see clearly when the highlight start to break.
John Z
    I assume you don't really want to reduce the speed but to reduce the time it takes (i.e. increase the speed), but regardless of that it's going to be very hard to make any suggestions without knowing the specifics of what you're doing (the sub-version of Virtuoso in use, the set up for Mark Net, the size of the design you're trying to mark, how long it takes currently, and so on). The best avenue for that would be to work with customer support.
