  3. Doing math on text.
  • Subscribers 152
  • Views 11595
Doing math on text.
MorrisDH
MorrisDH over 4 years ago
Pardon the vague subject title but briefly describing the issue is not easy.
Starting with a string that contains a 'list' of numbers. The word 'list' is in quotes because it is not a SKILL list.
String example: "250 350". There could be any number of elements and the values could be integer or float.
What is needed is to subtract a value for each element and the result is still a single string.
Example: Say we want to subtract 9.5 from each element.
input -> "250 350"
output -> "240.5 340.5"
This is what I came up with and it works fine but it feels a bit ad hoc. Wondering if there could be a better solution.
myString = "250 350"
numList = mapcar( 'evalstring parseString(myString)) ; returns (250 350)
adjustedList = foreach(mapcar x numList x-9.5) ; returns (240.5 340.5)
myNewString = buildString(foreach(mapcar x adjustedList sprintf(nil "%g" x))) ; returns "240.5 340.5"
The above works but would like to see alternative methods
    A cleaner way of setting numList would be this:
    numList=linereadstring(myString)
    and I would probably use lsprintf instead of sprintf since you only want the return value:
    myNewString = buildString(foreach(mapcar x adjustedList lsprintf("%g" x)))
    (potentially using %N rather than %g because in case the result of your operations were integers; can't be in this case because of the subtraction of a floating point, but that's more general).
    Other than that, it's pretty reasonable. The main difference is really using linereadstring as there's no need to involve the evaluator in this. I am always wary of using evalstring or eval when parsing arbitrary strings - for efficiency but also imagine what happens if myString was "exit() 3"?
  • MorrisDH
    MorrisDH over 4 years ago in reply to Andrew Beckett
    I didn't know about linereadstring. Thanks for the tip. I'll give it a try.
    Morris
  • MorrisDH
    It works perfectly and the code is cleaner. Used linereadstring, lsprintf, and %N.
