  3. Not getting correct directory path via browse button
  • Subscribers 152
  • Views 10785
saurabh96
saurabh96 over 4 years ago
Hello Everyone, greetings,
I am using below skill code-
path_enter=hiCreateStringField(
?name 'path_enter
?defValue "/xyz/cadence-/2021.12.28"
Entry=hiCreateButton(
?name 'Entry
?buttonText "Browse..."
?callback "FileDialog(hiGetCurrentForm())"
procedure(FileDialogCB(dialog event formName)
let(((form symeval(formName)))
when(event=='done
form->path_enter->value=car(hiFileDialogSelection(dialog))
procedure(FileDialog(form)
hiDisplayFileDialog(
?dialogName 'MyFileSelect
?mode 'directoryOnly
?callback "FileDialogCB"
?userData form->hiFormSym
the issue am getting when am pressing browse button it is showing the directories present in pwd(working area) not in path mentioned in string box ..i.e  /xyz/cadence-/2021.12.28.
what's the error and how to fix that when i press browse button it should show directories present in path string?
Thomas
    Try reading the documentation for the hiDisplayFileDialog. You'll see there's a ?workingDir argument, so just adding this to the hiDisplayFileDialog call within FileDialogCB will fix this: ?workingDir…
    ?workingDir form->path_enter->value
  • saurabh96
    saurabh96 over 4 years ago in reply to Andrew Beckett
    Thanks !
