  3. Search for particular string in patttern
  • Views 11084
saurabh96
saurabh96 over 4 years ago
Hello ...
Entry=hiCreateListBoxField(
?name 'Entry
?multipleSelect t
?choices (list "x_y_1 (diodes)" "x_y_10 (clamps)" "x_y_11 (Protections)"  ))
rules_check = buildString(
foreach(mapcar entry form->Entry->value
car(parseString(entry))
multi_check = parseString(rules_check)
numPat=pcreCompile("\\d")
rules_number=buildString(
pcreExecute(numPat entry)
pcreSubstitute(numPat "&")
when am running above code am getting values of rules_number  = 1,1,1 inspite it should be 1,10,11
where in code its wrong and how can i correct it?
BR,
The
  • AurelBuche
    AurelBuche over 4 years ago +1
    Hi, Your pcre is wrong, it can only match one digit (not a full number) Add a "+" at the end and it should work correctly numPat=pcreCompile("\\d+") Note that pcreSubstitute relies on rexMagic…
  • AurelBuche
    Note that pcreSubstitute relies on rexMagic, if anywhere in your Virtuoso session (rexMagic nil) is set your code will return "&","&","&" instead of "1","10","11"
    Hope this helps,
    Cheers,
    Aurélien
  • saurabh96
    saurabh96 over 4 years ago in reply to AurelBuche
    Thanks Aurel for guidance..
    What about this ?
    pcreSubstitute(numPat "\\0")
    Andrew Beckett over 4 years ago in reply to saurabh96
    saurabh96 said:
    What about this ?
    That will have the same behaviour as using &. Your pattern is wrong either way and this won't fix your incorrect regular expression.
    This is undocumented behaviour, and nobody should write code that depends upon it (I'm pushing for this to be fixed, because I think it's bad behaviour that can cause code to break).
