  3. Import symbol with property list into Skill++
  • Subscribers 150
  • Views 3585
FormerMember
FormerMember over 4 years ago
I have a global variable/symbol in normal Skill mode, where I store several settings in its property list. Some parts of the code must be run with Skill++, but it seems I can not import the symbols property list.
Example:
Normal Skill:
Var = 'Var
Var.a = 1
Var.b = 2
Skill++:
importSkillVar( Var )
Var.a >>> is nil
Is there a way to make the property list available in Skill++? I could not find any example or documentation for this case.
Best regards
Paul
    Paul,
    There's no importing that needs to be done. The property list should be visible in both language modes, because the properties are associated with the symbol, and the symbols are shared anyway. The Var='Var in your code doesn't do anything - it's just creating a variable called Var which references the symbol Var. The properties are on the symbol Var - so in either language mode doing:
    plist('Var)
    would return
    (b 2 a 1)
    You can indirectly access the properties this way:
    myVar='Var
    myVar->a ; outputs 1
    myVar->c=5 ; adds a new property to the Var symbol
    In that case you might want to import myVar so you can do the same indirection operation, but the property lists are shared anyway.
    I simply don't see what you're seeing. If I do:
    > Var.a = 1
    1
    > Var.b = 2
    2
    > toplevel('ils)
    ILS-<2> Var.a
    1
    ILS-<2> Var.b
    2
    ILS-<2> Var.c=5
    5
    ILS-<2> resume()
    nil
    > Var.c
    5
    as you can see, everything works. Doing the importSkillVar() or Var='Var makes no difference to the above behaviour.
  • FormerMember
    FormerMember over 4 years ago in reply to Andrew Beckett
    Thank you Andrew for your quick answer. I guess I made a mistake somewhere, because now it works as expected.
