  3. Adding menu item in SimVision
  • Views 10384
dragank
dragank over 4 years ago
Hi all.
I am using Virtuoso IC6.1.8-64b.500.17.
So far I used:
deRegUserTriggers("maestro" nil 'InternalMaestroAddMenu)
to add menu to maestro, but now I have to add menu to SimVision.
I am pretty sure that there is a way, but I can not find what to write instead of "maestro" ?
Thank you in advance.
    SimVision is not a Virtuoso application and doesn't use SKILL. So this would probably be better asked in the Functional Verification forum.
    However, there's an article which covers this (it talks about adding a button and also a menu):
    How to create a button in the Design Browser that will rename the Waveform window
