  3. Arithmetic calculation going wrong.
  • Views 10906
Abhishek G V
Abhishek G V over 4 years ago
Hello everyone,
I'm a student started working on SKILL automation, I m trying to write a skill program for automating the results of basic layout reviews, and i m facing issue in comparing float data. for Some data the comparison is successful, but for some even the data is same it's not showing it's same.
Case 1:
K=0    lly(2.660000) != tly[0](-0.140000)
K=1    lly(2.660000) != tly[1](0.420000)
K=2    lly(2.660000) != tly[2](0.980000)
K=3    lly(2.660000) != tly[3](1.540000)
K=4    lly(2.660000) != tly[4](2.100000)
K=5    lly(2.660000) == tly[5](2.660000)    ury(2.940000) != tuy[5](2.940000)
K=6    lly(2.660000) != tly[6](3.220000)
K=7    lly(2.660000) != tly[7](3.780000)
K=8    lly(2.660000) != tly[8](4.340000)
K=9    lly(2.660000) != tly[9](4.900000)
lly=2.660000    ury=2.940000
Metal-2 should be on track.
Case 2:
K=0    lly(2.100000) != tly[0](-0.140000)
K=1    lly(2.100000) != tly[1](0.420000)
K=2    lly(2.100000) != tly[2](0.980000)
K=3    lly(2.100000) != tly[3](1.540000)
K=4    lly(2.100000) == tly[4](2.100000)    ury(2.380000) == tuy[4](2.380000)
K=5    lly(2.100000) != tly[5](2.660000)
K=6    lly(2.100000) != tly[6](3.220000)
K=7    lly(2.100000) != tly[7](3.780000)
K=8    lly(2.100000) != tly[8](4.340000)
K=9    lly(2.100000) != tly[9](4.900000)
Metal-2 is on track.
here's the result of my program,
docs.google.com/.../edit
    You've not shared your code - not entirely sure how you would expect somebody to debug what's wrong with your code from just the output - but almost certainly this is a classic floating point rounding error mistake. It's always dangerous to compare floating point numbers with == in any language using IEEE floating point arithmetic (most languages).
    There are numerous posts on this with SKILL in particular and a google search would find many on the problem in general. For example here's a couple:
    • https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/41465/floating-point-rounding/1359883#1359883
    • https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/49378/weird-numerical-behavior/1378921#1378921
    If these are database coordinates, the safest way to compare is to get the cellView DBUperUU and round to integer before comparison. For example:
    procedure(CCFcompareXorY(n1 n2 DBUPerUU)
      round(n1*DBUPerUU)==round(n2*DBUPerUU)
    cvId=geGetEditCellView()
    DBUPerUU=cvId~>DBUPerUU
    ury=2.38
    tuy=2.38+1e-13 ; an example of a slight rounding error
    ury==tuy ;  returns nil
    CCFcompareXorY(ury tuy DBUPerUU) ; returns t
    There is also the nearlyEqual() function, but to be honest when comparing database values such as coordinates (which are really stored as integers), it's best to convert them to integers before comparing - that's going to be the best approach. nearlyEqual is better for general floating point comparison.
