  3. x vs y plot and transient plot strips
  • Views 12388
dragank
dragank over 4 years ago
Hi all.
I am using "IC6.1.8-64b.500.17".
I am plotting transient simulation results of few signals in different strips and that is functioning properly.
Signal selections and strip x and y scales are set up on form.
Occasionally user can select to plot custom calculated x vs y plot and when I try to put it in a strip along with transient plots Cadence does plot of x-y wave in new subwindow.
Is it because x axis values for transient and x-y plot values are not common ?
I just need confirmation if this is expected behavior .
Best regards,
Dragan
    Dragan,
    All graphs in a subwindow need to really share the same x-axis. You should be able to do right mouse over the x-axis and pick "allow any units" and then you can drag the curve onto that sub-window - whether the results make sense is up to you of course!
  • dragank
    dragank over 4 years ago in reply to Andrew Beckett
    Thank you, Andrew,
    Manual intervention step is enough for explanation.
    Best regards,
    Dragan
