  3. skill code to change end point according to new Design ...
  • Subscribers 152
  • Views 11455
skill code to change end point according to new Design rule
EJAZ27
EJAZ27 over 4 years ago
a horizontal drawing layer is need to be aligned with guide as shown in figure. i want to automate it. I don t have much experience in cadence skill. you can consider me as a beginner level. it can be either done by reading guide or manually giving input how much length layer needs to be extended or pulled back.
  • mbracht
    mbracht over 4 years ago +1
    Hi, I'am not exactly sure what you want to do - the summary says "change end point according to new Design rule..." and in the description you say you want to align a horizontal drawing layer. Changing…
  • mbracht
    I'am not exactly sure what you want to do - the summary says "change end point according to new Design rule..." and in the description you say you want to align a horizontal drawing layer. Changing the end point of a path is easy, the OA attribute on a path's database object is "points", it's value is a list of points. Since this is an attribute you can write to, all you need to do is to assign a new value to this attribute. To try this out just select the path and then:
    myPath = css()
    myPath~>points
    ...which returns the current points list. And then assign a new value to it - for example
    myPath~>points = (list (list 0.0 0.0) (list 0.5 0.0 ))
    To do this on all paths in a given design you need to iterate over all shapes of type path (assuming the design is available in a SKILL variable named cv):
    (foreach path (setof shape cv~>shapes shape~>objType=="path")
       path~>points = <new points list>
    Since your question is not very detailed (especially with respect to the new end point of the path according to a new design rule - what design rule?) I can only provide a very general approach.
    Max
  • psill00
    psill00 over 4 years ago
    Not sure of what you want. I have not tested this but it might get you in direction to what you want.
    I was not sure it is a path or pathSeg
    define the xgrid and ygrid in the command "stuff"
    procedure(stuff(xgrid ygrid)
    let( (pts pt
    (cv geGetEditCellView())
    foreach(path setof(shp cv~>shapes shp~>width)
    if(equal(path~>objType "path") then
    pts = rndPointList(path~>points xgrid ygrid)
    path~>points = pts
    else pt = rndPoint(path~>beginPt xgrid ygrid)
    path~>beginPt = pt
    pt = rndPoint(path~>endPt xgrid ygrid)
    path~>endPt = pt)
    t
    )) end of stuff
    procedure(rndNum(num grid)
    let( (tmp rem)
    tmp = fix(num/grid)
    rem = float(num - tmp*grid)
    if(lessp(rem grid/2) then
    num = num-rem
    else num = num + grid - rem)
    num
    )); end of rndNum
    procedure(rndPoint(pt xGrid yGrid)
    let( (x y)
    x = rndNum(xCoord(pt) xGrid)
    y = rndNum(yCoord(pt) yGrid)
    list(x y)
    )); end of rndPoint
    procedure(rndPointList(ptList xGrid yGrid)
    let( (x y rndList)
    foreach(pt ptList
    rndList = cons(list(x y) rndList))
    rndList
    )); end of rndPointList
    Paul
