  3. Make boolean buttons mutually exclusive
  • Views 11718
MorrisDH
MorrisDH over 4 years ago
Is there a preferred SKILL method for creating a group of boolean buttons that allow only one button to be selected?
  • MorrisDH
    I think I found the answer - hiCreateRadioField.
    Will give it a try.
  • MorrisDH
    hiCreateRadioField works but it wasn't exactly what I need. It appeared that at least one option always had to be selected and I wanted the ability to unselect all.
    Add a callback function to hiCreateBooleanButton instead of using radio field.
    procedure( mutuallyExclusiveBooleans(form selButton)
      let( ()
        case(selButton
          ("Option1"
            if(form~>Options1~>value == t form~>Option2~>value = nil))
          ("Option2"
            if(form~>Option2~>value == t form~>Option1~>value = nil)))
      ) ; let
    ) ; procedure
    The selButton option is text that is passed from the callback to indicate which button was pressed. There may be a better way to tell the function who is calling.
            hiCreateBooleanButton( ?name 'Option1
                                   ?buttonText "Option1"
                                   ?defValue 'nil
                                   ?buttonLocation 'left
                                   ?callback "mutuallyExclusiveBooleans(hiGetCurrentForm() \"Option1\")"
            ) ;Boolean
            hiCreateBooleanButton( ?name 'Option2
                                   ?buttonText "Option2"
                                   ?defValue 'nil
                                   ?callback "mutuallyExclusiveBooleans(hiGetCurrentForm() \"Option2\")"
            ) ;Boolean
    Not sure if this is the best way to go but it works.
    Andrew Beckett over 4 years ago in reply to MorrisDH
    You could also use a toggle field:
    toggles=hiCreateToggleField(
      ?name 'toggles ?choices list(list('Option1) list('Option2) list('Option3))
      ?prompt "Choose"
      ?callback list(
        lambda((field scope item value)
          unless(boundp('MyInCallback) && MyInCallback
            let(((MyInCallback t))
              ;printf("CB: %L %L %L %L\n" field scope item value)
              foreach(toggle field->_toggleItems
                unless(eq(toggle item)
                  get(field toggle)->value=nil
    hiCreateAppForm(?name 'MyForm ?fields list(toggles))
    hiDisplayForm(MyForm)
    This has a callback (specified as a function object because then you find out which toggle was selected) which loops over all toggles and turns off the one that wasn't just pressed. Note that it has this dynamic variable MyInCallback to determine whether it's already in the callback because otherwise turning them off also triggers the callback again which gets a bit tricky (you'd find that you have to press the item twice to turn it on, which would be a bit strange).
