  3. Drawing pressed key on Virtuoso Window
  • Subscribers 150
  • Views 13065
RicardoGV1
RicardoGV1 over 4 years ago
Is there a way of drawing on the window?
There are some solutions as the attached link which draws inside the cell, but I need to draw even if the user changes to schematic editor or another window.
and for the pressed key, also read an answer which said there was no code for that, but was a while ago.
Update: I used autoHotKey on windows
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/48/5873.ShowKeyPressed.zip
Drawing logo in schematic view
    Whilst I can think of ways of adapting the code in the attached link to draw using "hilight sets" (geCreateHilightSet etc) which would then not create anything in the database itself, it would be pretty…
    Andrew Beckett over 4 years ago in reply to RicardoGV1 +1
    I have no idea what that video is supposed to be showing me, but you can retrieve the current bindkey by using hiGetBindKey. Andrew
    RicardoGV1 said: That's why I was asking if there is a way of accessing those functions to copy the functionality. We do not provide the source code of our commands. Some of them are in C++ and some…
    Whilst I can think of ways of adapting the code in the attached link to draw using "hilight sets" (geCreateHilightSet etc) which would then not create anything in the database itself, it would be pretty cumbersome to do this. You'd have to modify every bindkey to call another function, probably have a timer to remove the hilight and so on. I don't think it's a particularly sensible thing to do.
    Instead, try searching on google for "screenkey". This is a Linux utility (available for many distributions or can be built from source - it's on GitHub) which can display key presses in a pretty configurable way. I've not tried it myself but there are a few videos showing it in use - this seems a far better way of doing it rather than re-implementing this within Virtuoso.
  • RicardoGV1
    RicardoGV1 over 4 years ago in reply to Andrew Beckett
    Thanks a lot Adrew, I'll be posting here what I found in case somebody else needed.
  • RicardoGV1
    As the "update" shows After your help I was working with autohotkey, but because company policies we are not using AutoHotKey or screenkey anymore.
    So I think I'm taking the other option of modifying every bindkey.
    I found this thing which writes on the screen. Just have two concerns. I don't want to use those functions as the CIW shows in the attached video, Is there a way to access those script lines or is hidden by cadence?
    and for the bindkeys, How do I save the previous bindkey function to rewrite it after the timer ends?
    Play this video
    Regards
    R. Gómez
  • RicardoGV1
    I'm sorry, I was trying to show that using the short locator functions _lceHiShortLocatorAddVirtualLabel1CB()  and lceHiShortLocatorForm->tabs->page1->netNameCombo1->value="text"  I'm able to drawn the text on screen.
    The thing is that this have some disadvantages If I call those functions net selector tool is activated,  then I must exit function after drawing every key and that I can't edit the way is displayed or placed. That's why I was asking if there is a way of accessing those functions to copy the functionality.
    *also I'm looking forward to modify those codes because I'll use that functionality to create others scripts.
    We do not provide the source code of our commands. Some of them are in C++ and some are in SKILL, but either way they are not something we provide for customers to copy and modify.
