  3. How to use ocnSetXLMode() command to set mode to XL.
  • Views 9983
lingtao jiang
lingtao jiang over 4 years ago
I try to use python script to load ocean script automatically in virtuoso. Then I got an error: "Mode not set as XL. Use ocnSetXLMode() command to set mode to XL."
I met this error at the first time. So what should I do? Change the ocean script? If  anyone know this, please tell me. Thank you so much!
Lingtao Jiang
    Presumably (and I do sometimes wonder why people post questions like this without actually sharing the script you're using), the script contains OCEAN XL functions but does not start with ocnSetXLMode…
    Presumably (and I do sometimes wonder why people post questions like this without actually sharing the script you're using), the script contains OCEAN XL functions but does not start with ocnSetXLMode(). So yes, if you're doing that you should modify the OCEAN script. If you don't think you're using OCEAN XL functionality, you will need to share the script so that anyone trying to help here stands some chance of being able to give advice!
