  3. Got a SYNTAX ERROR, does anyone meet this error?
  • Views 13890
lingtao jiang
lingtao jiang over 4 years ago
I use python script to load ocn file and skill script. Here is the ocean script:
setup(?numberNotation 'engineering)
simulator( 'spectre )
design( "/home/IC/simulation/LNA_test/spectre/schematic/netlist/netlist")
resultsDir( "/home/IC/simulation/LNA_test/spectre/schematic" )
modelFile(
'("/home/IC/Tech/TSMC-65nm(OA)/tsmcN65/../models/spectre/toplevel.scs" "tt_lib")
analysis('dc ?saveOppoint t )
analysis('ac ?start "10k" ?stop "1G" )
envOption(
'analysisOrder list("dc" "ac")
temp( 27 )
Then I got this in the terminal: SYNTAX ERROR found at line 1 column 39 of file *string*
*Error* lineread/read: syntax error encountered in input
Does anyone meet this error before?Could you give me some help?
  • lingtao jiang
    And here is the skill script:
    procedure( loadSimulator(runDir loadFile popSize)
    ; Change he running directory
    cd(runDir)
    ; Load the simulator
    load(loadFile)
    ; Set an environment variable with the number of evaluations per simulation
    ; run. At the begin, it is the population size.
    setShellEnvVar("SMOC_NUM_EVALS" popSize)
    msg = "loadSimulator_OK"
    procedure( updateAndRun(runFile varFile resultFile numSim)
    ; Update the circuit design variables
    load(varFile)
    ; Get the number of evaluations of the previous run
    numEvals = getShellEnvVar("SMOC_NUM_EVALS")
    numEvals = atoi(numEvals) ; Convert to integer
    ; Disable or enable the number of evaluations per required
    if( numSim < numEvals then
    for( i (numSim + 1) numEvals
    sprintf(testName "test:%d" i)
    ocnxlDisableTest(testName)
    else
    if( numSim > numEvals then
    for( i (numEvals + 1) numSim
    ocnxlEnableTest(testName)
    ; Update the env variable with the current number of evaluations
    sprintf(numSimStr "%d" numSim) ; Convert to string
    setShellEnvVar("SMOC_NUM_EVALS" numSimStr)
    ; Set the results file
    setShellEnvVar(resultFile)
    ; run the simulation
    load(runFile)
    msg = "updateAndRun_OK"
    procedure( sendData(cid msg)
    printf("[INFO] Sending message to server: %s\n" msg)
    ; First sends the size of the data to send
    ipcWriteProcess(cid sprintf(nil "%d\n" strlen(msg)))
    ; Then sends the data
    ipcWriteProcess(cid msg)
    procedure( requestHandler(cid request)
    let( (result resultStr)
    if( serverHasStarted <= 0 then
    if( request == "Python server has started!" then
    serverHasStarted = 1
    printf("[INFO] Cadence is talking to server! Waiting for a client connection...\n")
    else
    printf("[INFO] Waiting for server... Message: %s\n" request)
    else ; if server has started
    ; if the request is to call a function
    if( rexMatchp("(.*)" request) then
    ; The "errsetstring" evaluates the request and returns the result,
    ; if valid, or an error message. E.g. if the request is a function,
    ; it executes the function and returns the result.
    if( result = errsetstring(request 't) then
    sprintf(resultStr "%L\n" car(result))
    else
    sprintf(resultStr "%s\n" car(nthelem(5 errset.errset)))
    sendData(cid resultStr)
    else ; if the request is a message, prints that message
    printf("[INFOs] %s\n" request)
    procedure( errorHandler(cid errorMessage)
    warn("%s\n" errorMessage)
    procedure( exitHandler(cid exitStatus)
    printf("Server has stopped with the exit code %d. I'm out!!!\n" exitStatus)
    ocnxlEndXLMode() ; End XL mode
    hiRegTimer("exit()", 10) ; exit Cadence
    procedure( startServer()
    printf("[INFO] Starting server process...\n")
    serverHasStarted = 0
    cid = ipcBeginProcess("sh run_server.sh" "" 'requestHandler 'errorHandler 'exitHandler "")
    msg = "Python server has started!\n"
    ; Starts the server
    startServer()
    Andrew Beckett over 4 years ago in reply to lingtao jiang
    There's not really enough to go on here - there's no column 39 in line 1 of either file, but since the error seems to be coming from reading a string, my guess is that the error is being triggered by the errsetstring() in the requestHandler function, and so presumably is in the string being sent to it by whatever "run_server.sh" is doing.
    For example, if I do something like this:
    > errsetstring("6+7+" t)
    6+7+
    SYNTAX ERROR found at line 1 column 5 of file *string*
  • lingtao jiang
    lingtao jiang over 4 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thank you so much for helping me. I will try to find the error.
    Lingtao
