  3. How to edit/modify Help button in GUI using Skill
  • Views 3083
Drake96
Drake96 over 4 years ago
Am new to skill language and learning it,
I want to modify the Help button in Gui, that when i click it revert to my local pdf path.
Suppose i have test_pdf store in local path /xyz/abc/test.pdf
So when i click HELP button in GUI it revert to my path not to cadence help directories.
How can i do it.
Drake
    I'm assuming you're talking about a form you're creating yourself? This is covered in a section in the help headed "Specifying Your Own Callback for Help" - try searching for that in cdnshelp. Here's a small example:
    hiCreateAppForm(
        ?name 'MyHelpForm
        ?formTitle "How to customize help"
        ?fields list(
            hiCreateStringField(
                ?name 'entryField
                ?prompt "Enter something"
    MyHelpForm.hiHelpAction="MyHelpCB()"
    procedure(MyHelpCB()
        system("evince /xyz/abc/test.pdf")
    hiDisplayForm(MyHelpForm)
  • Drake96
    Drake96 over 4 years ago in reply to Andrew Beckett
    Hey Andrew,
    thank you very much
    yes am talking about the local form that i have created.
    am referring to   this "Help" option.
    if i click the above help option am able to open the pdf file which exists in path  /xyz/abc/test.pdf
