  3. How to generate & view files from GUI forum
  • Replies 7
  • Views 4525
Drake96
Drake96 over 4 years ago
hola!
I have created a GUI , which consists of several tech nodes (hiCreateCyclicField) - 5nm,10nm,14nm,28nm & and button "view sample text"
I want that when i click on 5nm and press button-> a sample text will be visible that contains eg --     "name - drake wick"
same when i click on 10nm -> a sample text generate and contains--  "needs help in skill"
Basically it will be sample file , visible but not editable...so for different nodes , different text appears.
How we can approach that?
Apologies if its not clear..am still in learning mode
Drake
  • mbracht
    mbracht over 4 years ago +1
    Hi Drake, I don't know what you mean when you say "a sample text will be visible". You want to see it in a dialog or in the CIW or what exactly? Below is an example that prints the sample text to CIW…
  • mbracht
    mbracht over 4 years ago in reply to Drake96 +1
    so you want a text file to be opened in readonly mode when you click the button right? This is what the view() function does. Just replace the println() statements against (view <nameOfTextFile>).
  • mbracht
    Hi Drake,
    Below is an example that prints the sample text to CIW - I leave it up to you to implement the "visibility" thing the way you want.
    (let (cyclicField btn form)
       cyclicField = (hiCreateCyclicField
                         ?name       (gensym)
                         ?choices    (list "5nm" "10nm" "14nm" "28nm"))
       btn = (hiCreateButton
          ?name (gensym)
          ?buttonText "view sample text"
          ?callback   (lambda (@rest args)
                         (case cyclicField->value
                            ("10nm"
                               (println "needs help in skill"))
                            ("5nm"
                               (println "that's pretty small!"))
                            (t
                               (printf "don't know what to do with %s\n" cyclicField->value)))))
       form = (hiCreateAppForm
          ?name (gensym)
          ?fields (list cyclicField btn))
       (hiDisplayForm form) )
    Max
  • Drake96
    Drake96 over 4 years ago in reply to mbracht
    Hello Max,
    I want it in text file form?
    Is it possible to happen that when am click 5nm a text file open, also that file should not editable
  • mbracht
  • Drake96
    Max,
    Sorry for trouble.
    when am replacing am gettting something like this..text is appearing as title and inside its empty-
  • mbracht
    <nameOfTextFile> must be the name of an existing(!) file - "that's pretty small" is not an existing file is it?
    Andrew Beckett over 4 years ago in reply to Drake96
    That won't work of course because it's trying to open a text file that doesn't exist and so it just shows empty contents. If you've used view() - you didn't say - that's exactly what it would do.
    Instead, try:
    procedure(CCFshowSomeTextInAWindow(theText)
      let((win)
        win=hiOpenWindow(?type "text")
        hiTextDisplayString(win theText t)
        win
    and replace the calls to println in Max's code with similar to this:
    (CCFshowSomeTextInAWindow "needs help in skill")
  • Drake96
    Hello Max,
    I tried the above option's, it worked very fine thanks for that..one follow-up question regarding that-
    eg-
    if the have one cyclic field that contains following check set-
    check=hiCreateListBoxField(
    ?name 'check
    ?multipleSelect t
    ?changeCB "CBCyclicRules(hiGetCurrentForm())"
    check1
    check2
    check3
    check4
    check5
    now,
    if(form->check->value = "check5" then
    op = outfile("./ffile" "w")
    fprintf(op "success { \n")
    close(op)
    (view "ffile")
    Now ,when am running above script, so inspite which option is select(i.e. check1,2,3,4,5) its given "success"
    I want that only when check5 is pressed then only it should print and view success.
    can you show where its getting wrong
    Kind regards,
    Drake
