  3. *WARNING* Form 'Form', field 'check': Bad value "check5...
  • Views 2613
*WARNING* Form 'Form', field 'check': Bad value "check5". Must be a list.
Drake96
Drake96 over 4 years ago
Hola everyone.
if the have one cyclic field that contains following check set-
check1
check2
check3
check4
check5
check=hiCreateListBoxField(
?name 'check
?multipleSelect t
?callback "back(hiGetCurrentForm())"
procedure(back(form)
if(form->check->value = "check5" then
op = outfile("./ffile" "w")
fprintf(op "success { \n")
close(op)
(view "ffile")
now,
Now ,when am running above script, so inspite which option is select(i.e. check1,2,3,4,5) its given "success"
I want that only when check5 is pressed then only it should print and view success.
can you show where its getting wrong
Kind regards,
Drake
    Andrew Beckett over 4 years ago in reply to Andrew Beckett +1
    By a full example, I mean something like this - note I've added the extra code to allow the code to be run (this is after I made the fix). You're far more likely to get help if you minimise the amount…
    Andrew Beckett over 4 years ago in reply to Drake96 +1
    As I explained before: Andrew Beckett said: The ->value of a listbox (because it can have multiple items selected) is a list not a string You are trying to print a string (with %s) but you are passing…
    Please provide complete examples - you seem to follow the pattern of your predecessor saurabh96 in not providing a full code example but snippets of code. Often that's not enough to show the problem.
    You talk in the subject line about cyclic fields, but this is not using a cyclic field. It's using a list box.
    Anyway, the problem is two-fold:
    1. Your callback is using "=" instead of "==". You're trying to check equality, not assign the value
    2. The ->value of a listbox (because it can have multiple items selected) is a list not a string
    Changing the condition in the callback function to:
    if(form->check->value == list("check5") then
    fixes the problem.
    By a full example, I mean something like this - note I've added the extra code to allow the code to be run (this is after I made the fix). You're far more likely to get help if you minimise the amount of work somebody has to do when responding here - we're all doing this in our own time (including the Cadence folks like me - it's not part of my role at Cadence to respond here). If it involves a lot of repeated effort, you're likely to get ignored...
    ; indented the code to make it readable
      ?name 'check
      ?multipleSelect t
      ; the list of choices was missing
      ?choices list("check1" "check2" "check3" "check4" "check5")
      ; fixed the condition
        close(op)
        (view "ffile")
    ; added a small form around the field to show the problem
    hiDisplayForm(
      hiCreateLayoutForm(
        'forum114
        "Forum114"
        hiCreateFormLayout(
          'lay
          ?items list(check)
  • Drake96
    Drake96 over 4 years ago in reply to Andrew Beckett
    Andrew, am sorry for unclear quotations-
    thanks it was clear.
    i have write below code in which am trying that if i select all check together i get output like check1 success
    check 2 success.
    check 3 success.
    check 4 success.
    check 5 success.
    ?name 'check
    ?multipleSelect t
    fprintf(op "%s success \n" form->check->value)
    close(op)
    (view "ffile")
    hiDisplayForm(
    hiCreateLayoutForm(
    'forum114
    "Forum114"
    hiCreateFormLayout(
    'lay
    ?items list(check)
    if am selecting all rules and running ,error prompt is- *Error* fprintf/sprintf: format spec. incompatible with data - "Format is '%s success \n', argument #1 is (\"check1\")"
    You are trying to print a string (with %s) but you are passing a list (as the error message states). Simplistically you could just change the %s to %L.
