  3. How to access all elements of tabView of config view by...
  • Views 11316
How to access all elements of tabView of config view by a simple method because hdbTraverse.il is too complex
zsummer
zsummer over 4 years ago
Hi, all,
The config view content is shown in below.
Table View | Tree View |
Library    | Cell                     | View Found | View to Use | Inherited View List
a             | b                         | schematic   |                      | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
a             | and_or_inv          | schematic  |                      | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
a             | inv                       | schematic  |                      | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
tsmcNxx | inv_svt_mac        | schematic |                       | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
tsmcNxx | nand2_svt_mac  | schematic |                        | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
tsmcNxx | nor2_svt_mac     | schematic |                        | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
tsmcNxx | nch_svt_mac       | schematic |                        | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
tsmcNxx | pch_svt_mac       | schematic |                        | spectre cmos_sch cmos.sch schematic veriloga ahdl pspice dspf
I want to get all elements of tabView of config view by an easy method, like as hiGetCurrentForm() or hiGetCurrentWindow(),
but hiGetCurrentWindow()~>?? cannot access 'Library', 'Cell', 'View Found', 'View to Use', ‘Inherited View List’.
This should have actually like using GUI command: "File -> Save Cell Table Data -> HE_lib_cell_config.csv".
1. is there any skill function to do "File -> Save Cell Table Data -> HE_lib_cell_config.csv"?
2. I know there are a $CDSHOME/tools/hdb/examples/hdbTraverse.il to call hdbOpen(), hdbBind()... to do it.
but it has about 812 lines, I cannot spend too much time to understand it.
Whether there is an more easy, simple, fast method to access 'Library', 'Cell', 'View Found', 'View to Use', ‘Inherited View List’ info from config view window?
such as hiGetCurrentWindow()~>?? or hiGetCurrentForm()~>??
3. support.cadence.com/.../ArticleAttachmentPortal has a bit simple example to get top level 'instance,matserlib,mastercell,masterview' of the schematic view,
but cannot list top-1, top-2...bottom level 'instance,matserlib,mastercell,masterview'.
How to list top-1, top-2...bottom level 'instance,matserlib,mastercell,masterview'?
4. support.cadence.com/.../ArticleAttachmentPortal use 'hedConfigTraverse libName.cellName:viewName -output myfile' to do it.
hedConfigTraverse is a unix utility, we can use system("hedConfigTraverse...") to use it.
but I still wonder that how to access all elements of 'Table View' of config view directly by use hiGetCurrentWindow()~>??
Thanks in advance
    You can just use File->Save Cell Table Data to save the information into a CSV file.
    If you want to do this entirely from SKILL without using the hierarchy editor interface, it needs something to traverse the hierarchy. I've written the code in this example post  RE: Config View Assignment which utilises my "abSchTree" code (in the same post) which handles the complexity of the traversal and then just adds the additional information to collect the data. The abCollectCellViewsInConfig.il code collects this data, but excludes the stopping views; I think you should be able to easily alter it to capture all views in the cell table by changing the condition (removing the isStoppingView part) in abSchTreeOutputElement in that file.
    Traversing the hierarchy with a config is a little complex, so you don't need to worry about the full complexity necessarily. Hopefully the built-in menu in the hierarchy editor does what you want anyway!
    Andrew Beckett over 4 years ago in reply to Andrew Beckett
    I should have also explicitly answered your question:
    The answer to that is "no".
  • zsummer
    zsummer over 4 years ago in reply to Andrew Beckett
    Thanks for your explanation and instruction.
    one more question: is there any skill function or method to simulate mouse click 'OK'  button event  when  small window popup  after 'File->Save Cell Table Data'.
    Thanks in advance.
    Andrew Beckett over 4 years ago in reply to zsummer
    Not really. The expression for the OK button is generated based on the window, and is private. Even if I try to enqueue it after launching the private function to invoke the save cell table date form, it doesn't work. So this isn't a supported approach. Why do you need to do it from SKILL if this is a UI feature of the hierarchy editor?
