  3. select shape or mosaic
  • Views 13089
StanleyChiu
StanleyChiu over 4 years ago
My company does not allow uploading pictures,so I use MS Paint to draw the layout sample
I want to implement this function,when i select a shape or mosaic's edge (the red line is being select)
it can be select
(PS:I'm not very good in English,so I hope my pictures can convey what I mean,If there are any questions, I will try to reply)
thanks!!
    OK, so you've presumably selected using partial selection (F4 toggles this). If you want to convert partial selections into full selections, you can do: foreach(obj geGetSelSet() geSelectFig(obj)) …
  • StanleyChiu
    StanleyChiu over 4 years ago in reply to Andrew Beckett
    thank you very much !!
  • AurelBuche
    AurelBuche over 4 years ago in reply to Andrew Beckett
    geSelObjectsPartiallySelected also does the job and take in account selection granularity when objects are fully selected
    Cheers
    Aurélien
    Andrew Beckett over 4 years ago in reply to AurelBuche
    Thanks Aurélien!
    I knew there was a function to do this but was in an airport when I answered and hadn't the opportunity to check for the function name.
  • AurelBuche
    Yes, using this function as a bindkey callback also has the nice perk of showing it directly in the menu
    (hiSetBindKey "Layout" "ctrl<key>s" "geSelObjectsPartiallySelected()")
