  3. Redirecting the output of a script into a text file when...
  • Views 10386
Redirecting the output of a script into a text file when in a loop
Peat
Peat over 4 years ago
 ic6.1.8 (19)  I can't seem to find a helpful link anywhere...
Dealing with two separate *.il files and one output file to write to.
script_1  prints what it finds to the CIW (the things I want it to and it works great).
script_2  opens an outfile(report_file), loops through a list of cells and invokes script_1 when a valid condition is found.
I cannot find a way to get the output of script_1 into the report_file.
All the fprintf statements in script_2 get into the report_file, but none of the printf() statements from the call to script_1.
I have attempted many combinations of things, all to no avail.
What am I missing?  ((thank you in advance))  Here's an oversimplified example of the essence:
script_1:
procedure( script_1( lay sch)
let( ()
printf("\nChecking through lay and sch \n Found something or nothing\n printing results here:\n")
printf("\nDone with printing what was found... or not\n")
));let proc
script_2:
procedure( script_2( lay sch)
let( (report_file listofcells lay sch)
report_file=outFile( filenamefromform~>value )
listofcells==(getOrMakeAListOfCells)
foreach( cell listofcells
fprintf(report_file "\n looking for lay and sch to give script_1\n")
fprintf(report_file "Found and sending to script_1\n")
script_1( lay sch)         ;;;;<-- what is the right call here to get script_1 text into the report_file?? CIW is not enough
fprintf(report_file "Done with script_1\n")
);foreach
close(report_file)
(view filenamefromform~>value nil "Report _ File" )
));let proc
    In script_2 change the call to script_1(lay sch) to the following:
    let(((poport report_file))
      script_1(lay sch)
    This will override the poport variable (using dynamic scoping) to be set to report_file and any printing will go into report_file instead. When the let ends, the previous value of poport will be restored.
