  3. Retriving Info from Tree Items
  • Views 11287
kdolan
kdolan over 4 years ago
Hi, I am trying to familiarize myself with how to make tree's via Cadence Skill and then how to insert them into a GUI. Where I am getting stuck is retrieving information from the selected tree items.
I've added some simple code below as an example. My intentions are for when the user clicks the button ('getTreeItemInfo), this function will return the values from the headers of the selected items. For example, the users selects item0 in the tree, this should return (1 101 201), the three values from headers for item 1. This would ideally also work for multiple selections.
Any help is greatly appreciated.
Keelan
procedure( TreeGUI()
prog( (TreeGUIForm treeGuiField getTreeItemInfo)
treeGuiField = hiCreateTreeTable(
?name 'treeGuiField
?headers list(list("Counter" 125 'left)
list("Counter +100" 125 'left)
list("Counter +200" 125 'left)
?choice getMyTree()
getTreeItemInfo = hiCreateFormButton(
?name 'getTreeItemInfo
?buttonText "Get Item Info"
?callback "hiTreeTableGetSelectedItems(TreeGUIForm~>treeGuiField)"
TreeGUIForm = hiCreateAppForm(
?name 'TreeGUIForm
?formTitle "Tree Test"
?fields list(
list(treeGuiField 10:15 410:350 10)
list(getTreeItemInfo 10:370 100:30 10)
?dialogStyle 'modeless
?buttonLayout '(OKCancelApply)
?initialSize t
hiDisplayForm(TreeGUIForm)
);let
);procedure
procedure(getMyTree()
prog( (outputTree outputTreeItem)
outputTree = hiCreateTree('outputTree)
for(i 1 10
outputTreeItem = hiCreateTreeItem('outputTreeItem list(sprintf(nil "%L" i) sprintf(nil "%L" i+100) sprintf(nil "%L" i+200)))
hiTreeAppendItem(outputTree outputTreeItem)
return(outputTree)
);prog
);procedure
    The main issue you had was that each tree item needs to be a unique symbol (you were using the same for all items). I've adapted your code slightly and added a callback function to print out the selected…
    The main issue you had was that each tree item needs to be a unique symbol (you were using the same for all items). I've adapted your code slightly and added a callback function to print out the selected information:
          ?name 'treeGuiField
          ?choice getMyTree()
          ;?callback "hiTreeTableGetSelectedItems(TreeGUIForm~>treeGuiField)"
          ?callback "PrintTreeSelectedItems(TreeGUIForm~>treeGuiField)"
          ?name 'TreeGUIForm
          ?fields list(
          ?initialSize t
      );let
    );procedure
        for(i 1 10
          ; each tree item needs to be a unique symbol
          outputTreeItem = hiCreateTreeItem(concat('outputTreeItem i) list(sprintf(nil "%L" i) sprintf(nil "%L" i+100) sprintf(nil "%L" i+200)))
        return(outputTree)
      );prog
    );procedure
    procedure(PrintTreeSelectedItems(field)
      foreach(item hiTreeTableGetSelectedItems(field)
        printf("Selected: %L : Description: %L\n"
          item hiGetTreeItemDescription(symeval(item))
  • kdolan
    kdolan over 4 years ago in reply to Andrew Beckett
    That was my issue! Works perfectly now. Thanks Andrew!
  • AurelBuche
    AurelBuche over 4 years ago in reply to kdolan
    Hi, you should also note that hiCreateTree... functions create your objects and associate them in SKILL top level namespace
    This can lead to bugs in case you duplicate your code or reuse the same names somewhere else
    You should wrap your symbols using gensym  to avoid problems in the future
    hiCreateTree(gensym('outputTree))
    hiCreateTreeItem(gensym('outputTreeItem) ...)
    Hope this helps
    Cheers
    Aurélien
