  3. Similar tool / script like "size" for resizing of MPP ?...
  • Views 1894
Similar tool / script like "size" for resizing of MPP ??
Laurentz
Laurentz over 4 years ago
I am using Vituoso IC 6.1.8 for layout and I searching for a tool like "size" for resing of MPP guardrings.
I have the issue that the guardring is too close to some resistor and generates  drc errors and to fix them I have to stretch the guardring to outside in all directions by some distance. It would do the same thing like "size" comand is doing for rectangles or polygons.
Does somebody have a script for this purpose ?! Or can you give me an idea ?
I want to select a MPP guadring and then by calling a function with the Spacing as argument the guardring should be stretched in all directions. The argument can be positive or negative AND the shape of MPP can be a rectangle or polygon kind.
Best regards,
  • Laurentz
    Laurentz over 4 years ago in reply to AurelBuche +1
    Aurelien, this is great ! Your tools works very good, as long the enclosure subpaths of the MPP do not have offsets. Thank you ! Best regards, Laurent
  • AurelBuche
    AurelBuche over 4 years ago
    You might try something like this, it works but it is not bulletproof
    (inScheme
    (let nil
      (defun closed_polygon? (points)
        "Return t if POINTS describe a closed polygon, nil otherwise"
        (let ((p0 (car points))
              (p1 (car (last points)))
          (destructuringBind (x0 y0) p0
            (destructuringBind (x1 y1) p1
              (and (nearlyEqual x0 x1) (nearlyEqual y0 y1))
      (defun close_polygon (points)
        "Return a closed list of POINTS"
        (if (closed_polygon? points) points
          ;; Here we close the polygon in the middle of a segment
          ;; This avoids many issues with path enclosures (happening at corners)
          ;; Adding a check to make sure this segment is either horizontal or vertical could be a good (necessary?) idea
          (let ((mid_pt (centerBox (list (car points) (car (last points))))))
            (cons mid_pt (append1 points mid_pt)))))
      (defglobalfun size_mpp_gr (@key (ring (css)) size (snap_mode "orthogonal") @rest _args)
        "Grow or shrink MPP RING, increasing it by SIZE"
        (assert ring                          "Nothing selected")
        (assert (equal ring->objType  "path") "Selection is no path")
        (assert (rodGetObj ring)              "Selection is not an MPP")
        (assert (numberp size)                "Please provide a valid size")
        (letseq ((cv     ring->cellView)
                 (points ring->points)
                 (closed (closed_polygon? points))
          (setq points (pcGrowPoints points size))
          ;; This did not work properly as I'm not sure how to use `geClosePolygon'
          ;; (it seems to only return the list of missing points)
          ;; And `geCompressPointArray' closes the polygon on a corner
          ;(when closed (setq points (geCompressPointArray cv (append points (geClosePolygon cv points snap_mode)) nil)))
          (when closed (setq points (close_polygon points)))
          (setf ring->points points)
      ));SKILL++ closure
    Cheers,
    Aurélien
  • Laurentz
    Aurelien, this is great !Slight smile
    Thank you !Wave
    Best regards,
    Laurent
