  3. *WARNING* (Parser): character found after backslash is not...
  • Subscribers 150
  • Views 2429
*WARNING* (Parser): character found after backslash is not meaningful - '\$'
ebecheto
ebecheto over 4 years ago
Dear AB, (i mean All Buddies, not necessary Andrew B. :-)
I try to play a bit with auto-creation of a user library :
path=if(getShellEnvVar("PRJ_DIR") "\${PRJ_DIR}/cds/design" "./")
lib=dbCreateLib(userLib path) techSetTechLibName(lib getShellEnvVar("ATTACH_LIB")||"SG13_dev") ddUpdateLibList()
Although, the two lines are evaluate and results in the correct creation of the library and its input in cds.lib as :  DEFINE 65n_ebecheto ${PRJ_DIR}/cds/design
The CIW windows blame me of an error :
PARSER WARNING at line 25 column 36 of file *ciwInPort*
I tried to mute the error with er=errset("\${PRJ_DIR}/cds/design" nil)  for instance, but is still throw the error.
Any one already faced this behaviour ?
    I'm not sure why you are trying to escape the $, but "\$" doesn't mean anything in SKILL, hence the error. You either need to use "${PRJ_DIR}..." or "\\${PRJ_DIR}..." if you need an escape character there…
    I'm not sure why you are trying to escape the $, but "\$" doesn't mean anything in SKILL, hence the error. You either need to use "${PRJ_DIR}..." or "\\${PRJ_DIR}..." if you need an escape character there for some reason. Having checked it, I don't think you want the backslash at all...
  • ebecheto
    ebecheto over 4 years ago in reply to Andrew Beckett
    indeed, i did not need the backslash at all in the case. I had  twisted my  mind for unnecessary reasons. Thanks
