  3. My custom gui button is getting pressed even before hitting...
  • Views 10765
My custom gui button is getting pressed even before hitting the button.
Purbayan
Purbayan over 4 years ago
I wrote a code where i want to  takes the input from field SF1 and SF3 and when pressed the press me button the callback function will execute a function where it takes values from both the string field.
But the issue is that i when i create the display the form layout  even before pressing the press me button the callback function is getting executed.
I have also attached my code
I would love to have this call back function mapped to ok button but i am unable to do so
procedure(Create_input_form()
FORM2=hiCreateLayoutForm(
'NPN_
"NPN "
hiCreateFormLayout(
'main_layout
?spacing 10
?label_align 'center
?items (list
a=hiCreateStringField(
?name 'SF1
?prompt "SF1 "
?editable t)
hiCreateSeparatorField(
?name 'sep1)
?name 'SF2
?prompt "SF2"
?editable t)
b=hiCreateStringField(
?name 'SF3
?prompt "SF3"
?editable t)
hiCreateButton(
?name 'button
?buttonText "Press me"
?callback buttonCB(a b))
));main_layout
);display_form
hiDisplayForm(FORM2))
procedure(buttonCB(a b)
printf("Button pressed - field:%s scope:%s\n"
a~>value b~>value
    That's because you're calling the function when you use: ?callback buttonCB(a b). You need to pass either a string to be executed, or a function object. I thought initially (based on your definition of…
    That's because you're calling the function when you use: ?callback buttonCB(a b). You need to pass either a string to be executed, or a function object. I thought initially (based on your definition of the callback) that you wanted to use the function object way of doing this, in which case you'd change the callback to:
    ?callback getd('buttonCB)
    but then the function would fail because the arguments are strings to the printf - you could fix that to be:
      printf("Button pressed - field:%L scope:%L\n"
        a b
        ;a~>value b~>value
    but given that you're assigning two variables a and b as the fields are created, I suspect this is not what you want it to do. Passing a and b to the callback doesn't make much sense because it will likely get executed out of scope - although you have a and b being global variables, so it would work - but it would be poor code. You could just change
    ?callback "buttonCB(a b)"
    and keep your original buttonCB definition. It's not a field and scope being accessed then, so it's misleading.
    Better would be to change the code like this:
      let((FORM2)
          'NPN_
          "NPN "
          hiCreateFormLayout(
            'main_layout
            ?spacing 10
            ?items (list
                ?name 'SF1
                ?prompt "SF1 "
                ?editable t)
                ?name 'sep1)
                ?name 'SF2
                ?prompt "SF2"
                ?editable t)
                ?name 'SF3
                ?prompt "SF3"
                ?editable t)
              hiCreateButton(
                ?name 'button
                ?callback "buttonCB(hiGetCurrentForm())"
          ));main_layout
        );display_form
    procedure(buttonCB(form)
      printf("Button pressed - field1:%s field3:%s\n"
        form->SF1->value form->SF3->value
    You should also clean up your function names - with names like that you're likely to collide with some other code. Best practice is to start all your functions with a prefix, beginning with an uppercase letter so that you don't clash with other functions.
  • Purbayan
    Purbayan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew for the response and suggestions, those really helped me a lot.
    Yours
    Purbayan
