  3. I have correct cell name still it is throwing error.
  • Views 10822
Purbayan
Purbayan over 4 years ago
I wanted to check if library and cell exist or not
my code works like this first it checks if library exist or not, if library doesn't exists it throws an library error dialogue box, if library exist  then it goes to check if cell exist or not, if it exist it will print correct if not it will throw cell error dialogue box.
The problem i am facing is even if cell name is correct it is still throwing cell error dialogue box and also printing correct
Here is my code
case(ddGetObj(Lib_name)
(nil
hiDisplayAppDBox(
?name 'ERRORBOX1
?dboxBanner "ERROR"
?dboxText sprintf(nil "Incorrect Library name")
?dialogType hicInformationDialog
?dialogStyle 'modal
?buttonLayout 'Close))
(t
if(equal(ddGetObj(Lib_name CELL_name) nil) then
hiDisplayAppDBox(
?name 'ERRORBOX2
?dboxBanner "ERROR"
?dboxText sprintf(nil "Incorrect Cell name")
?dialogStyle 'modal
else printf("COREECT"))
    I can't see how that would happen - it doesn't when I try it. The code is a little odd - it's a rather strange use a case function. There is an extra close parenthesis in the code, but that shouldn't cause…
    I can't see how that would happen - it doesn't when I try it. The code is a little odd - it's a rather strange use a case function. There is an extra close parenthesis in the code, but that shouldn't cause the problem.
    Anyway, a better way would be to do this with a cond() function which is conceptually similar to an if/elseif/elseif/elseif/else construct:
    cond(
      (!ddGetObj(Lib_name)
        hiDisplayAppDBox(
          ?name 'ERRORBOX1
          ?dboxBanner "ERROR"
          ?dialogStyle 'modal
      (!ddGetObj(Lib_name CELL_name)
        hiDisplayAppDBox(
          ?name 'ERRORBOX2
          ?dboxBanner "ERROR"
          ?dialogStyle 'modal
      (t
        printf("CORRECT")
    BTW, I'm not sure if your code has indentation in it normally and it just got lost during pasting, but code is much easier to understand with indentation (see my code above).
  • Purbayan
    Purbayan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew very much for the response.
    Even i also ended up using if else if else way.
    Purbayan
  • AurelBuche
    AurelBuche over 4 years ago in reply to Andrew Beckett
    Be careful with
    as it will return a non-nil value (the dd_lib actually) even if CELL_name is nil or a blank string
    you should use
    ddGetObj(Lib_name CELL_name)->type == 'ddCellType
    instead
    Cheers
    Aurélien
