  3. How to get the object id of deleted instance, net, wire...
  • Replies 8
  • Views 13345
How to get the object id of deleted instance, net, wire or anything?
Purbayan
Purbayan over 4 years ago
For example if someone with GUI deletes an object from schematic i want to get the object id of that deleted object.
I am doing this in order to update my list/report field so that i can remove that element/ choice from my list/reportfield.
  • AurelBuche
    AurelBuche over 4 years ago
    Hi Purbayan,
    Your issue is not really clear...
    Are you talking about a native GUI or a custom one?
    If it is a native one, you won't be able to do anything except if there is a public trigger you can edit to update your report field
    If it is a custom one (and you can edit it), you will have to update it's callback to update your field
    Otherwise this is not optimal but you can check the values of your field and remove the elements not present in the schematic
    The harder part is to define when you update your field...
    Otherwise if the GUI you are referring to is the schematic editor, you can rebind the "delete" key to a custom function that will do the deletion and update your report field accordingly
    Hope this helps
    Cheers
    Aurélien
    Andrew Beckett over 4 years ago in reply to AurelBuche
    There are no triggers on deletion (presumably it would have needed to be on pre-deletion anyway as otherwise getting the id of something already deleted wouldn't have made sense anyway). Rebinding the delete key is only going to help if you've deleted that way and not used the delete in the context menu, the Edit menu, the Edit toolbar - fixing all of those would start getting complicated - and even then if "repeat commands is enabled" it's hard to know when you're done with deleting. The options as I see it are one of:
    1. Provide a "refresh" capability on your UI to update the data shown in the table based on pressing a button on the form
    2. Validate any selection to make sure that the data still makes sense at the time of the operation
    3. Make the form modal so that you can't delete anything anyway as the UI would block further interactions until OK'd
  • Purbayan
    Purbayan over 4 years ago in reply to AurelBuche
    Hi Aurélien,
    Actually what i want is if a user deletes an object from schematic with usual delete key i just want to get the object id of that specific object and delete that entry from the list also. I want to trigger it when user clicks delete(the usual delete function provided by cadence donot prove any feedback on what  object id got deleted).
    The second Method that you suggested is check the schematic, the problem with this is if a schematic have more than 10000 objects then checking updating will be very slow with foreach loop. If there is any faster way available to do that i would really appreciate it.
    Also thank you for the valuable suggestions.
    Yours
    Purbayan
  • Purbayan
    Purbayan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew I will make sure to follow the suggestions, what i am thinking is adding a refresh button to my appform so that the table will be refreshed, but is there any efficient and fast way to scan a schematic if it have more than 10000+ components.
    Yours
    Purbayan
    Andrew Beckett over 4 years ago in reply to Purbayan
    It really should not take very long to look at 10,000 components in the schematic - the database access itself should be quick. It rather depends on what you're doing with the results, I guess or what information you're collecting.
  • AurelBuche
    AurelBuche over 4 years ago in reply to Purbayan
    Actually it depends on what you want to do precisely
    If you have to browse the hierarchy, your script might take more time to run.
    You also might want to avoid prints that will be time consuming and quite useless with such a number of objects
    If you don't need to parse the instances, you might want to use instances headers instead to reduce the number of processed items
    You should also avoid returning the list of >10000 objects in your code and might consider using generators instead
    ;; This is to avoid as it keeps all the instances at the same time in memory
    insts=(geGetEditCellView)->instances
    foreach inst insts ...
    ;; This should be a little better:
    ;; Browse instances headers
    (let ((inst_header_gen (dbStartGenInstHeader (geGetEditCellView)))
          inst_header)
      (while (setq inst_header inst_header_gen->next)
        ;; Browse instances
        (let ((inst_gen (dbStartGenInstHeaderToAnyInst inst_header))
              inst)
          (while (setq inst inst_gen->next)
    ;; Put your body here
            ));insts
        ));inst_headers
  • Purbayan
    Thank you Andrew, It cleared my doubt .
  • Purbayan
    That is really great insight.
    Thank you Aurélien for the code.
