  3. Executing sequential commands in Virtuoso
  • Views 11681
DanRitt
DanRitt over 4 years ago
I am interested to execute sequential commands to move objects for demonstration purposes. I need to show an object MOVE, wait few seconds and another object MOVE, etc...
I am using ipcBeginProcess(N) + pcWait(cid) commands to create a SLEEP functionality between commands.
The main goal is to perform the next sequence:
1. Move an object (For Example: A rectangle of M1) to a certain location.
2. Wait 3 seconds
3. Move another object to another location.
4. Wait 3 seconds.
5. Move another object to another location.
The issue: Currently I am not getting a delay between commands. Instead, Virtuoso waits the entire sum of all delays and then executes all MOVE commands at the same time. There is no delay between move commands.
I tried using sleep(N) function and I am getting the same results. Somehow the delay is executed once and all objects move at the same time after the delay.
Any tips would be greatly appreciated.
Thanks.
Danny
Here is the code:
procedure(moveOBJ()
let((mySelSet x cv i cid)
cv=geGetEditCellView()
CCSselectNet("NET1")
mySelSet=geGetSelSet()
printf( "\nMoving NET1\n")
foreach(x mySelSet
dbMoveFig(x cv list(0:0.021 "R0" 1))
geDeselectAllObject(cv)
; WAIT 3 SECONDS
cid=ipcBeginProcess("sleep 3")
ipcWait(cid)
CCSselectNet("NET2")
printf( "\nMoving NET2\n")
foreach(x mySelSet
dbMoveFig(x cv list(0.002:0 "R0" 1))
; WAIT 3 SECONDS
ipcWait(cid)
CCSselectNet("NET3")
printf( "\nMoving NET3\n")
foreach(x mySelSet
dbMoveFig(x cv list(0:0.007 "R0" 1))
);let
);proc
    Actually it does do the changes each time, but the UI isn't updated because everything is blocking and so you don't see the change.
    You need to call hiUpdate to update the windows. See the code below:
    fig=car(geGetSelSet())
    for(i 1 3
      dbMoveFig(fig fig~>cellView list(3:0 "R0" 1))
      hiUpdate()
    ; might possibly need this too
    ;  hiFlush()
      ipcSleep(2)
    Note too that you can use ipcSleep(n) rather than using ipcBeginProcess.
  • DanRitt
    DanRitt over 4 years ago in reply to Andrew Beckett
    The solution works.
    Thanks Andrew.
