  3. SKILL API dbCreateTextDisplay()
  • Views 13723
AkshayMD
AkshayMD over 4 years ago
What are d_associateId and d_ownerId in the SKILL function dbCreateTextDisplay()?
Can anyone give  examples for these two?
    Andrew Beckett over 4 years ago in reply to AkshayMD +1
    That's simply because you have Label Origins turned on in the Options->Display. The + will be drawn for both labels and textDisplays if this is turned on - and it's so you can locate where the origin of…
    The associate is the object that you are displaying a property/attribute of - i.e. the linked object to show information about in the label. The owner is the object to which the text display is attached (i.e the textDisplay's parent is this object). Having a parent-child relationship means that if the owner is moved, the textDisplay moves with it.
    Does that help?
  • AkshayMD
    AkshayMD over 4 years ago in reply to Andrew Beckett
    Hey Andrew, Thanks for the quick reply.
    Here the object is any instance like a pcell?
    Is there a way in which I can display a user given text in the layout editor at a specified location using some metal layer or base layers like OD POLY etc?
    The associated object is an instance, or a net, or a terminal - something in the database with an attribute you want to display - so for example you want to display the name of an instance or net - and if that instance name changes, the "label" will display automatically. You can display it on a given layer as you wish.
    If you want to display arbitrary text, use dbCreateLabel instead. In that case you specify the text to display as an argument to the function.
  • AkshayMD
    I tried with dbCreateLabel, this will display the text with a '+' sign in the beginning. I wanted to get rid of that because I am trying to display say some 4 letters in a metal layer and without any space the next 4 letters in some other metal layer and so on but the '+' sign in between every word would look a disturbance for the viewer.
    That's simply because you have Label Origins turned on in the Options->Display. The + will be drawn for both labels and textDisplays if this is turned on - and it's so you can locate where the origin of the labels are.
    hiGetCurrentWindow()->textJustificationOn=nil
    will turn those off for the current window.
    envSetVal("layout" "textJustificationOn" 'boolean nil)
    will (usually) change the default.
  • AkshayMD
    Thanks So much Andrew!..
