  3. envSetVal trimEnable not working
  • Subscribers 152
  • Views 10288
iDoLayout
iDoLayout over 4 years ago
envSetVal("layout" "trimEnable" 'boolean t)
envSetVal("layout" "trimEnable" 'boolean nil)
Neither of these are toggling the Trim setting off/on.  Is this a known issue or am I doing it wrong??
I created a toggle on/off script for a bindkey, but I haven't been able to use it.
    Once a window is opened, this is controlled by a window property rather than the cdsenv - that's just used the seed the window settings (this is true of most display settings). So hiGetCurrentWindow…
    So hiGetCurrentWindow()->trimEnable=t is what you want. Or hiGetCurrentWindow()->trimEnable=!hiGetCurrentWindow()->trimEnable will toggle it.
