  3. Prevent Window GUI to become current window
  • Subscribers 150
  • Views 11029
AurelBuche
AurelBuche over 4 years ago
Hi All,
I created a quite complex GUI that I need as a window (with toolbar, no buttons, a specific icon etc.)
(hiOpenWindow ?type "form" ?form my_custom_form)
However this window (which is not attached to any session) is becoming the current one and prevents me from accessing current cellview (from the CIW)
1> geGetSelectedSet
*WARNING* (GE-2015): There is no cellview assigned to window(5) because the window is not a graphic editor window, or because it has been corrupted.
Make sure that your current window is a valid graphic editor window or contact customer service to investigate this issue.
nil
1> css
*WARNING* selectedSet: No current cellView.
nil
Is there any mean to prevent my custom window from becoming the current one instead of a design cellview one?
I guess I can still write my own get_current_window, get_current_cellview and get_selection functions and filter the session windows but can I easily retrieve the top bottom order of the windows (instead of the index order)?
Cheers,
Aurel
    Hi Aurel,
    windowId->neverCurrentWindow=t
    will do what you want.
  • AurelBuche
    AurelBuche over 4 years ago in reply to Andrew Beckett
    This solution looks so simple and obvious it is both awesome and frustrating
    It works perfectly as usual
    Thanks Andrew
