  3. How to make a default for Plugins Simulation as other
  • Views 11265
TonyTang
TonyTang over 4 years ago
I want to let schematic menu "Launch-->Plugins-->Simulation-->Other" as a default active for "Simulation".
While I open a new schematic, the number of "\&Simulation10" will be changed if I check "schematicTools->PluginSlider->??" in CIW.
Is there any way to trigger it while open any schematic view?
Thank you!
    This would do it:
    procedure(CCFaddOtherPluginTrigger(args)
      deInstallPlugin(args->window "Other")
    deRegUserTriggers("schematic" nil nil 'CCFaddOtherPluginTrigger)
  • TonyTang
    TonyTang over 4 years ago in reply to Andrew Beckett
    Work well, Thank you so much!
  • TonyTang
    One more question continue this, I want to let "Netlist and Simulate" form auto update field like "lib name, cell name" for current schematic cell.
    I try below code, but not work as my understand. I hope to trigger a skill after "Netlist and Simulate"  form pupup.
    I know if set a bindkey can achive it. But I hope to work it by menu way not from bindkey. Thanks for your kindly support.
    procedure(Update_simRunNetAndSim()
         let((lib_name cell_name)
         lib_name=hiGetCurrentWindow()->cellView->libName
         cell_name=hiGetCurrentWindow()->cellView->cellName
         simRunSimAndNetForm->simFormSimLibName->value= lib_name
         simRunSimAndNetForm->simFormSimCellName->value= cell_name
    procedure(simTrigger())
      when(hiIsFormDisplayed(simRunSimAndNetForm)
    deRegUserTriggers("schematic" nil nil 'simTrigger)
    Andrew Beckett over 4 years ago in reply to TonyTang
    I've not really done much customisation of this interface (we don't have too many customers using this old simulation interface), but at the very least your trigger is not defined with the required args argument which is a disembodied property list. So it will fail (silently) with an error and nothing will happen.
    I did do this - which seems to work. It does the initialisation at schematic open time (not at the time of launching the netlist/simulate menu), and I think it works. Note that it also sets a few variables because if the run directory is already initialised it picks up settings from there. I haven't really tested this to check what the full consequences are, so if this doesn't work you should contact customer support.
      when(boundp('simRunSimAndNetForm)
        simRunSimAndNetForm->simFormSimLibName->value=args->libName
        simRunSimAndNetForm->simFormSimCellName->value=args->cellName
        simRunSimAndNetForm->simFormSimViewName->value=args->viewName
        simLibName=args->libName
        simCellName=args->cellName
        simViewName=args->viewName
  • TonyTang
    Hi Andrew
    It works perfectly as what I want. Thank you so much!
