  3. Open Layout Instance in New Tab doesn't work in Ic 6.1.8...
  • Subscribers 152
  • Views 2506
Open Layout Instance in New Tab doesn't work in Ic 6.1.8.500.13
Laurentz
Laurentz over 4 years ago
Hi all,
I am using Ic 6.1.8.500.13 and I am a little bit frustrated because a skill script from Cadence support - CCSOpenCellViewInTabWindow.il - doesn't work at all under this Ic version.
When I am looking at a layout with subcells I want to open one of subcells in an new tab and actually a new tab appears with the wanted layout BUT there is no Layout Menus at all !!
I get this message in CIW : *Error* (Default-writer-method) generic:__de_set_installing class:_DEWindow
In the earlier IC versions this has worked !
Is there a workaround/fix for this error ?!
Thank you & regards
  • Marc Heise
    Marc Heise over 4 years ago
    Hi Laurentz,
    I found an existing report with that error which was  fixed in the next release.  6.1.8.5000.14 and above should be good.
    Kind regards,
    Marc
  • Laurentz
    Laurentz over 4 years ago in reply to Marc Heise
    Thank you Marc for the information.
    But I am forced by project to use this IC version. So for me the issue is still there. Disappointed
  • Laurentz
    Laurentz over 4 years ago in reply to Laurentz
    As alternative way I found this solution : open cellview from dynamic selection and redirect to new tab. Voila !
