  3. CPH ID and soft block ID
  • Views 10401
AkshayMD
AkshayMD over 4 years ago
How to find CPH ID and soft block ID when using cphSbSetRectangularBoundary() SKILL API
    cphGetLayoutXLConfig(layoutCellView) will give you the CPH id for the physical config from the layout view in use, or you can use  cphFindOpenConfig/cphOpenConfig to get it from a lib/cell/view of a physConfig view. cphSbGetSoftBlockId is how you'd get the soft block id. There's also cphSbGetSoftBlocks, and cphSbDefineSoftBlock to create one in the physical config.
    Note I've never used these functions - I'm just getting this from reading the documentation.
