  3. Rename all labels of an instance in a schematic
  • Views 12005
multiverse
multiverse over 4 years ago
Is it possible to change all label names of an instance using skill script?
For example, when I add instance in a schematic and hit "space" bar then it creates all the labels based on port name of an instance. I would like to add a suffix "_sv" to all these labels.
Is there an easy way to change all label names and add this common suffix to all labels?
Thanks.
    I quickly threw this together. Select the instances (which already have the wire stubs and labels) and then call CCFaddSuffixToWireLabels("_sv")
    procedure(CCFaddSuffixToWireLabels(suffix @optional (insts geGetSelSet()))
      let((pinBox wireShapes cv)
        cv=car(insts)~>cellView
        foreach(inst insts
          when(inst~>master
            foreach(term inst~>master~>terminals
              foreach(pin term~>pins
                foreach(fig pin~>figs
                  ; Having iterated over terminals, pins and figures,
                  ; transform up to the parent cellView and find overlapping
                  ; wires
                  pinBox=dbTransformBBox(fig~>bBox inst~>transform)
                  wireShapes=dbShapeQuery(cv '("wire" "drawing") pinBox 0 0)
                  foreach(wire wireShapes
                    ; Then look for any attached labels and add suffix
                    foreach(label wire~>children
                      when(label~>objType=="label"
                        label~>theLabel=strcat(label~>theLabel suffix)
        t
