  3. When ddGetObj is used for a constraint file, it appears...
  • Views 9568
When ddGetObj is used for a constraint file, it appears to do more than just getting the object
Byron Caloz
Byron Caloz over 4 years ago
This is what I put in a script:
; sv is the schematic cell view
cobj = ddGetObj(sv~>libName sv~>cellName "constraint" nil nil "r")
I need the object to get various data within the constraint file.
My intent is NOT to change the file or the constraints in any way.
Yet when this happens it appears as if the constraint manager wakes up and finds problems with the constraints and puts the constraint cache in edit mode.
I don't want this to happen, so I added the following code:
if(cobj then
  cc = muffleWarnings(ciCacheGet(sv))
  if( cc then
    muffleWarnings(ciCacheDiscardEdits(cc))
    muffleWarnings(ciCacheMakeReadOnly(cc))
I am concerned that there would be problems for users when actually attempting to make changes in the constraint or might undo changes they had made previously.
what is the best way to access constraint data without waking up the constraint manager?
