  3. How Can i distinguish the mouse click and drag in enterfunction...
  • Subscribers 152
  • Views 11427
How Can i distinguish the mouse click and drag in enterfunction???
jjoon2
jjoon2 over 4 years ago
HI, Sir
I have a question about input by mouse click.
I'm using the following function (using enterfunction).
"(command --> Mouse Click X 2 (objects select) --> Auto Property Change )"
But I want to add a new function.
after entering the command, if you select an area by dragging the mouse rather than clicking the mouse,
i want to you to do a different action on teh objects in the area.(It's a different behavior than the input through the mouse click.)
So I need to know How can i distinguish the mouse click and drag in enter function.
Please, Can i get some hint?
"(command    --> Mouse Click X 2 (objects select) --> Auto Property Change1
                      --> Mouse drag Input(area select)     --> Auto Property Change2)"
      • procedure(CCFtestEnter()
            unless(boundp('RoutingAssistanceForm)
                RoutingAssistanceOptionForm()
            ; store some properties on the form to record objects selected
            RoutingAssistanceForm.firstSelection=nil
            RoutingAssistanceForm.firstPoint=nil
            RoutingAssistanceForm.secondSelection=nil
            RoutingAssistanceForm.secondPoint=nil
            enterPoints(
                ?prompts list("First Object" "Second Object")
                ;   ?points list(0:0)
                ?form RoutingAssistanceForm
                ?alwaysMap t
                ?wantPoints 2
                ?initProc "CCFtestFun" ; init / addPoints / delPoints / done
                ?doneProc "CCFtestDone"
                ?addPointProc "CCFtestAddPointProc"
        procedure(RoutingAssistanceOptionForm()
            let((tempIndex)
                tempIndex=hiCreateFloatField(
                    ?name 'tempIndex
                    ?value 10.0
                    ?callback "CCFtestprint()"
                    ?prompt "RoutingAssistanceOptionForm"
                hiCreateAppForm(
                    ?name 'RoutingAssistanceForm
                    ?formType 'options
                    ?buttonLayout 'HideCancelDef
                    ?fields list(
                        list(tempIndex 0:0 400:30 100)
        procedure(CCFtestFun(wid)
            geSetEnterFunctionSelectionMode(wid 4)
            t
        procedure(CCFtestAddPointProc(wid pointList)
            let((newPt selection)
                ; probably want to record the two selections
                newPt=car(last(pointList))
                geSingleSelectPoint(wid nil newPt)
                selection=geGetSelSet()
                if(RoutingAssistanceForm.firstSelection then
                    RoutingAssistanceForm.secondSelection=selection
                    RoutingAssistanceForm.secondPoint=newPt
                else
                    RoutingAssistanceForm.firstSelection=selection
                    RoutingAssistanceForm.firstPoint=newPt
        procedure(CCFtestDone(wid ok pointList)
            printf("FIRST point %L selection %L\n"
            printf("SECOND point %L selection %L\n"
  • psill00
    psill00 over 4 years ago
    You need to load the stroke key functions to define stroke/draw feature
    To the the install path          getInstallPath()
    from your install path go to the stroke directory ( from the dfII go to the path below )
    dfII/etc/sted/
    files needed to load into cadence session
    def.strokes    ( binary file of the stroke definitions )
    defstrokes.il  ( your bindkey definitions )
    sted.env      ( environment stuff )
    stroke.il       ( cadence stuff )
    you will need a command line to bring up the gui to create your stroke keys/definitions
    readme file have the command line to bring up the stroke def gui
    I am not sure how well the stroke functions are supported now, but if you get some practice they are handy.
    Paul
  • psill00
    psill00 over 4 years ago in reply to psill00
    If you do a search for stroke in the forum you can see the method to defining the stroke for scripts or cadence functions
    Paul
    This question was re-asked in the this subsequent post.
