  3. viaMinNumCuts Expected Behavior
  • Views 8967
Kevin Buck
Kevin Buck over 4 years ago
I've set the minimum number of cuts cdsEnv variable to 2 but it only seems to take effect after I open the wiring assistant window which is a little bit annoying. Is this the expected behavior? As an example below you can see a wire I created on the left before opening the window and a wire created on the right after opening the wiring assistant (but not editing any settings).
