  3. abeLayerTouch result question
  • Subscribers 152
  • Views 12305
BorisD
BorisD over 4 years ago
Greetings,
 I have a script which takes as input a string expression like this "PC touch CA touch M1 touch (...)"  etc. This expression can have arbitrary length and represents connectivity information. I created a parser based on Advanced Boolean Engine (abe) routines to check if the expression evals to t/nil. For 'touch' operation I use abeLayerTouch which works perfectly fine:
abeLayerTouch( abeLayer1 abeLayer2 abeResult )
The issue I have is that the resulting abeResult contains only the tiles from abeLayer1 that touch abeLayer2. But for my purpose, I need to continue checking using the entire islands from abeLayer1 that touch segments from abeLayer2.
QUESTIONS:
  1. Is there a way for abeLayerTouch to return the entire island (aka polygon) instead of just the partitioned tile ?
  2. If not, any suggestions for alternative way to get what I want? I was trying to come up with a solution entirely within ABE realm, because of how quick it is. However, I finally resorted to loops and geometry.
  3. Are the islands in geoLayer OR abeIslandIterator sorted by default for number of points?
  4. For checking if a concave polygon is touching a rectangle, I couldn't find anything better than dbPointArrAnd, any ideas here? It felt really slow since for some reason it requires cellView and moreoever, I don't need it to return the overlapping area, I need boolean answer. So I wrote a 2 step algorithm, which profiled and turn out to better:
    1. Check if the sum of radiuses (r1 + r1) of smallest enclosing circle around two polygons is less then the distance between the circle center points L. If L>r1+r2 then polygons don't touch and stop here.
    2. Else check if at least one line N of polygonA is crossing|abutting line K of polygonB. If yes - polygons are abutting or straddle stop here.
      NOTE: This algorithm does not detect when polygonB is entirely inside polygonA without any abutting or crossing lines. However, this is not possible for my scenario with the abeLayerTouch.
 I ended up writing my own abeLayerConnect proc that performs what I need, but it can get slow with large number of polygons/islands and/with many points. I basically perform a standard abeLayerTouch, then for each tile from abeResult I check if it belongs to any islands from abeLayer1, if yes - I put them into a new abeLayer using abeLayerOrPtArray and continue with my expression using this new layer.
abeLayerTouch(abeLayer1 abeLayer2 abeResult)
;# Create array filled with tiles (threat tile as polygon for consistency)
ii=abeIslandIterator(abeResult)
tilesCount = ii->count
declare(aTiles[tilesCount])
for(i 0 tilesCount-1 aTiles[i] = ii->next)
;# Create array filled with polygons/islands
ii=abeIslandIterator(abeLayer1)
polysCount = ii->count
declare(aPolys[polysCount])
for(i 0 polysCount-1 aPolys[i] = ii->next)
;# Iterate over each polygon and check if a tile is touching.
;# If yes - add the polygon points to a new cumulutive abeLayer using abeLayerOrPtArray and 'remove' it from array. Remove the tile as well
;# because one tile can be part of exactly 1 polygon/island. Stop the loop and retry with new reduced number of polygons and tiles.
;# If no - just remove it from array -> none of the tiles were part from this particular polygon.
abePolys = abeNewLayer()
while(!zerop(tilesCount) || !zerop(polysCount)
  prog( (polygon tile)
    for( i 0 length(aPolys)-1
      polygon = aPolys[i]
      when(!eq(polygon 'unbound)
        for(k 0 length(aTiles)-1
          tile  = aTiles[k]
          when(!eq(tile 'unbound) && dbPointArrAnd(cv list(polygon) list(tile)) ; OR my custom made function which is actually faster
           abeLayerOrPtArray(polygon abePolys)
            aPolys[i] = 'unbound
            aTiles[k] = 'unbound
            tilesCount-=1
            polysCount-=1
            return(t)
          ); when
        ); for k
      ); when
      polysCount-=1
    ); for i
  ); prog
); while
abePolys
Any tips and/or ideas are appreciated. Thank you!
  • sebcliq
    sebcliq over 4 years ago in reply to AurelBuche +2
    3. Are the islands in geoLayer OR abeIslandIterator sorted by default for number of points? To the best of my knowledge, the island iterator does not do any kind of sorting - it is designed to deal with…
  • AurelBuche
    AurelBuche over 4 years ago +1
    Hi, Here is my solution for 1) and 2) It might be faster than yours and is one step closer to the ABE only realm (defun abe_layer_connect (abe_l0 abe_l1 abe_out) "Add ABE_L0 islands that touch…
  • AurelBuche
        "Add ABE_L0 islands that touch (completely overlap, partially overlap or abut) ABE_L1 to ABE_OUT"
        (let ((abe_touch  (abeNewLayer))
              (abe_island (abeNewLayer))
              (abe_tmp    (abeNewLayer))
        ;; First we compile the touching shapes using the default ABE function
    ;; Then we browse abe_l0 islands and keep the ones overlapping pre-compiled touching shapes
        (abeLayerTouch abe_l0 abe_l1 abe_touch)
        (let ((iter (abeIslandIterator abe_l0)))
          (while (setq island iter->next)
            (abeClearLayer abe_island)
            (abeClearLayer abe_tmp)
            (abeLayerOrPtArray island abe_island)
            (abeLayerAnd abe_island abe_touch abe_tmp)
            (unless (zerop abe_tmp->numTiles) (abeLayerOrPtArray island abe_out))
        ;; Delete useless layers and return the desired one
        (abeRemoveLayer abe_touch)
        (abeRemoveLayer abe_island)
        (abeRemoveLayer abe_tmp)
        abe_out))
    Hope this helps
    Cheers
    Aurélien
  • sebcliq
    To the best of my knowledge, the island iterator does not do any kind of sorting - it is designed to deal with millions of shapes as fast as possible, and any kind of sorting would basically kill performance.
    For question 4, I would maybe use geometrical algorithm based on dot product to check if a point belong to a segment or not. Then there is classical algorithm to determine whether a point is inside a polygon or not, based on the sign value of the sum of angles from point to all adjacent pairs on point in polygon [it does not work if point is exactly on boundary, so I complement it with first part of answer]
    Then as a general comment, it is generally more efficient in SKILL[++] to write a "specific language: based on list than based on strings, because list parsing is immediate in SKILL.
    Instead of
    I generally  prefer to write
    (touch PC CA M1 ... (and ... (or ... ) )
    Which is must easier to parse [use lineread !]
    And then for example create a SKILL++ object from the layers (PC, CA...) and method to assemble your objects [which in the end point to geoLayer of course]
    This is actually what we did in our company (write a SKILL++ class system on top of ABE, then write a "boolean language parser" - we encapsulate and "augment" all ABE functions into methods working on our objects.
    I cannot share the code here for obvious legal reasons, but this may be a way you want to pursue - at least, I can tell you this is working very fine for us, and people seem happy with this SKILL++ layer on top of ABE (I guess Aurelien can confirm ;-) )
    Sebastien
    • Vote Up +2 Vote Down
  • BorisD
    Hi Aurel,
     Thank you for your input! I've tested your approach but I hit a hard show stopper with abeLayerOrPtArray() function, which appears to have a limit for maximum size of list of points per polygon (l_points) and throws an error for invalid list. I could not find the exact number, however from experiments it appears to be somewhere between 3K and 6K points. This limitation prevents the code from executing on mesh like (chocolate bar) shapes, because of sheer number of points as it threated as polygon. In some scenarios I have as much as 12K points.
     I obviously cannot arbitrary slice the list of points to allowed size and process them in turns (or can I ?). So using abeLayerOrPtArray() is a no go and invalidates both yours and mine solutions for for such polygons...
    On a side note: have you noticed performance improvement when you explicitly use abeRemoveLayer() call when you are done with certain geoLayer?
    Hey Sebastian,
     Thanks for chiming in. This is pretty much exactly what I am also trying to do. I do leverage SKILL++ class system, but I use strings instead of lists because A) this would be main way to supply input to the code and B) I personally think infix notation (A+B) is easier on the eyes for people not familiar with Lisp than prefix notation (+AB)  : )
     I am not familiar in details with the algorithm you are referring to, but I can search around the web for more detailed explanation and try it as alternative for mine.
     From few experiments, I couldn't conclusively conclude whether abeIslandIterator() (or how geoLayer data is presented) doesn't at least follow some logic when you go over the islands. In my test, the polygon with most points was never last in the list. This is just me thinking if I can reap any benefit from choosing reverse order of traversing in case I have to keep with my solution.
  • AurelBuche
    AurelBuche over 4 years ago in reply to BorisD
    About abeRemoveLayer I haven't noticed anything but I haven't try neither...
    I guess you could use the profilers to check if it increases the performances. It might be interesting to do but should require meaningful testcases (your layouts seem complex enough though)
    To me the behaviour I expect is just for Virtuoso to make the generated layers available for the garbage collector to clear them when memory is required
    And from my developer point of view I want my function to act as a black box which just does what is defined in its docstring and does not pollute its environment
