  3. Veriloga Convergence Issues with DFF
  • Views 14576
greywanderer
greywanderer over 4 years ago
I am using the code below for a d-flip-flop. Its basically copied from designersguide.com and modified. It seems that there are convergence issues depending on whether V(qb,gnd) is defined or not. Could you guys please provide some guidance on what might be happening here?
Thanks!
`include "constants.vams"
`include "disciplines.vams"
// d flip flop with reset (reset is active high) and parameterizable initial state
module dff2 (clk, d, reset, q, qb, gnd);
input clk, d, reset; output q, qb; inout gnd;
voltage clk, d, reset, q, qb, gnd;
parameter real v0=0;
parameter real v1=1 from (v0:inf);
parameter integer dir=1 from [-1:1] exclude 0;
parameter real td=0 from [0:inf);
parameter real tt=0 from [0:inf);
parameter integer init_state=0 from [0:1];
integer actNow, out, state;
real thresh;
analog begin
    thresh = (v0+v1)/2;
    actNow = 0;
    @(initial_step or cross(V(clk,gnd) - thresh, dir)) begin
        actNow = 1;
    end
    out = idt(0, V(d,gnd)>thresh, actNow);
    V(q,gnd) <+ transition(out ? v1 : v0, td, tt);
    V(qb,gnd) <+ v0 + v1 - V(q,gnd);
end
endmodule
"Error Report"
Periodic Steady-State Analysis `pss': estimated fund = 650 MHz
Trying `homotopy = gmin'.
Trying `homotopy = source'.
Trying `homotopy = dptran'..
Trying `homotopy = ptran'..
Trying `homotopy = arclength'.
None of the instantiated devices support arclength homotopy. Skipping.
Error found by spectre during DC analysis, during periodic steady state analysis `pss'.
ERROR (SPECTRE-16080): No DC solution found (no convergence).
The values for those nodes that did not converge on the last Newton iteration are given below. The manner in which the convergence criteria were not satisfied is also given.
Failed test: | Value | > RelTol*Ref + AbsTol
Top 10 Solution too large Convergence failure:
V(u65:idt0) = 0 V
update too large: | -1 V | > 0 V + 1 uV
Top 10 Residue too large Convergence failure:
V(u65:idt0) = 0 V
residue too large: | -1 V | > 5 mV + 1 uV
  • greywanderer
    td, tt have been set to 10ps.
    Andrew Beckett over 4 years ago in reply to greywanderer
    Not enough to go on - a simple instantiation of the flip flop works, so it probably depends on how the flip flop is connected up. For example:
    I1 (clk d reset q qb 0) dff2 td=10p tt=10p
    V1 (d 0) vsource dc=1
    V2 (reset 0) vsource dc=0
    Vclk (clk 0) vsource type=pulse val0=0 val1=1 rise=1p period=10n width=5n
    ahdl_include "forum152.va"
    pss pss fund=100M
    converges with no problem (at least in SPECTRE21.1 ISR10).
  • greywanderer
    greywanderer over 4 years ago in reply to Andrew Beckett
    The flip flop is connected to act as a divide by 2
  • greywanderer
    greywanderer over 4 years ago in reply to greywanderer
    To debug this issue, the model was simplified to remove the change in "actNow" at initial_step. The model seems to be having issues with the "-ive" sign on the definition of V(qb,gnd).
    The question that I am stuck on is what is definition of the model at DC?
    - "cross" should be ignored which means that actNow is 0.
    - does this mean that "out" = 0 too, since actNow is 0 and idt is reset. how does idt behave under DC analysis?
  • greywanderer
    Wondering if you have sometime to help with this.
    Thanks much!
