  3. modifying elements of a list in a foreach loop
  • Views 11784
jaleco
jaleco over 4 years ago
How would one modify the list elements using a foreach loop?
For example :
L1=list('("a" "b"))
L2=list('("c" "d"))
L3=list('("e" "f"))
foreach( l list(L1 L2) l=append( l L3 ))
The foreach loop processes the index variable "l" each time but does not modify the value of the list elements L1 & L2.
    You could use destructive list modification to modify the lists in place - append will not do that. Use nconc instead:
    foreach( l list(L1 L2) nconc( l L3 ))
  • jaleco
    jaleco over 4 years ago in reply to Andrew Beckett
    Yes, this works - thank you so much Andrew!
